Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-08-2009, 12:48 AM   #11
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
Vehicle: 2006 Ford Mustang GT
Doc there is no doubt in needing a catch can (esp for FI). When I pulled off my intake (since I have FI now) the butterfly's were all oiled up...not a lot but only had maybe 3K miles on the car.
Not sure if a 0.5 sec gain from this mod is really that accurate but it does prove that the factory system is not very good at all and a catch can is a must for improved performance and longevity of the motor. Many conditions (as you know) can influence/change or improve/worsen the times like weather (temp, humidity, barometric pressure, etc).
__________________
2006 Mustang GT with Cervinis Kit
Whipple Crew member
H.O. S/C 465 RWHP and 440RWTQ
First online article about my car! check it out!
http://www.examiner.com/examiner/x-8811-Detroit-Sports-Car-Examiner~y2009m5d30-Jason-McGuires-2006-Mustang-GT
http://www.cardomain.com/ride/3342086
www.mocsem.com
mygt500 is offline   Reply With Quote
Old 10-08-2009, 12:58 AM   #12
S197winstang
S197winstang's Avatar
Vehicle: 2006 Mustang GT
Great post. I ordered the Steeda separator. Goes on next Friday.
__________________
Go:V3 Brenspeed STD, Bassani X pipe, JBA Shorties, FRPP 3.73, Spintech Super Pro Axle back, X3 Tuner, Steeda oil separator. Tune: Brenspeed 91 custom V3 Electronics: Alpine 505P1 nav/dvd, Autometer cobalt wideband+boost/vac Show: Blue LED maps, Halo Fogs, Silverstar bulbs.
Dyno/Installs: GTR
S197winstang is offline   Reply With Quote
Old 10-08-2009, 02:45 PM   #13
Doc Holiday
Doc Holiday's Avatar
Quote:
I wouldn't think that it would gain 0.5 seconds either, but then again all of the conditions were pretty close. If you look on the datalogs, you can see on the left hand side that the intake air charge was within a few degrees and the baro was within 0.6 or so. However, both runs were made on the exact same stretch of highway, and all of my previous datalogs (before the catch can) showed the same timing spikes and had the same time span between the same RPM's and speed. I'd split the difference between the intake air temp/baro and the oil catch can.... lol.
I think with the ECU having to pull timing like it was, it could definately affect the acceleration.
__________________
06 GT 5-spd, Shkr 500, JLTII 93, BMR LCA's, CMDP's, SLP LM's, Roush hd scp, rear 1/4's, Cervini B2 chin, 35% 3M tint, 17x9 BB 255/50/17 Nitto 555 front, 17x10.5 BB 315/35/17 Nitto 555 rear.
Doc Holiday is offline   Reply With Quote
Old 10-08-2009, 02:46 PM   #14
Doc Holiday
Quote:
Originally Posted by Rubrignitz View Post
What are you datalogging with?
SCTII with Livelink.
__________________
Old 10-08-2009, 03:19 PM   #15
VRFlip
Vehicle: 2010, Ford, Mustang GT Premium w/ Track Pack
Quote:
Do you have a link? All I can find is one that their website shows is for up to 2004 mustangs.
VRFlip is offline   Reply With Quote
Old 10-08-2009, 03:33 PM   #16
Cal26Stang
Cal26Stang's Avatar
Vehicle: 2007 Ford Mustang GT
Send a message via AIM to Cal26Stang Send a message via Yahoo to Cal26Stang
good to know.
__________________
2007 Black Mustang GT
Blackout taillights
SLP Loudmouths
Diablosport 93 Tune
Hurst Short Throw
Pioneer p4000-avhdvd
10% tint
Selling my pony tri-bar caps ask me...
Cal26Stang is offline   Reply With Quote
Old 10-08-2009, 04:47 PM   #17
Doc Holiday
Just one thing to remember, leave the brass filter inside of the DIY oil catch can. I have heard of people removing the filter, or drilling holes in it to promote airflow. I had holes drilled in mine at first, then got another filter since the hoses allow more airflow than the stock PCV tube. After installing the new filter, I pulled the hose off of the PCV at idle and it had PLENTY of vacuum. People that say they still saw oil getting through probably removed the filter or drilled holes in it.
You can see the brass filter inside of this one:
__________________
Old 10-08-2009, 04:52 PM   #18
S197winstang
Quote:
If you read on it tells you that it is for use on any car. They just have instructions for the 2004. I bought my unit from my performance shop-GTR they are also installing it. I have 0 technical ability.
__________________
Dyno/Installs: GTR
Old 10-08-2009, 09:22 PM   #19
nineinchnail1024
Kudos for doing what is arguably the most important mod on S197 mustangs. I installed a Moroso unit a couple years back and noticed an immediate gain in WOT performance.
__________________
Whipple Crew-10psi-Spec II-BMR LCAs-BMR sway bar delete-Spydershaft-M/T 26x11.5x17-Hurst-Prothane Mounts-PMP Line locks-Flows-Thump_rrr-Moroso separator-11.39@119mph
Daily Driver-2010 Prius-52.3mpg since new
Beater-1995 F150 XL-302 5spd
nineinchnail1024 is offline   Reply With Quote
05, 2005, 50, catch, diy, gt, gt500, install, installation, mustang, mustangoil, oil, s197, stef, turbo
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
