Vehicle: 2006 Mustang GT Premium Auto - Vista Blue
Quote:
Originally Posted by crescent_wrench
Can I have an "emissions tune" loaded, keep my aftermarket CAI on, and pass a sniff test? I really don't want to have to put the stock air box back on every year.
Yes. The sniff test cares only about the cats.
If all you have is the OBD-II test, you can get an emissions tune for just about everything. Excluding an O/R mid-pipe of course. People have passed with everything else though.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
Heres a easy way around it. In Illinois emissions is based on population. I couldn't believe it either till some of the people on this site said they live here and dont have to do emission testing. So with a little research you might be able to. Go to your emissions website and see if there is any county's or town small enough that are exempt. If there is and not too far away drive there,go to local post office and buy a P.O. box. Then register your plates to the P.O.box. Go back to emission website change address of plates to P.O.box and you are now exempt from emissions. Its hillarious, Good luck, theres always a loop hole.
__________________
05 GT Mustang,Auto, Dark Mineral silver.NOS,Added stripes and Hood scoop,Steeda pulleys,SCT Tuner,Brenspeed tune,TCI stall,Coast DS,AEM Induction,Sequential tailights,410s,Kooks LT,Crane cam stg II.
Quote:
Some states have filled in that loop hole. Texas is one of them. Luckily here, only certain counties have emissions.
Quote:
Originally Posted by doode
What makes a tune an "emissions" tune?
I thought if you have an off road H with your O2 sensors still on, they will trip a CEL.
An emissions tune is where all sensors are turned on and everything is working properly to not set a CEL. An O/R pipe will kill any chance of having an emissions tune since the O2's will throw a code pretty quickly. You need cats for an emissions tune to do any good.
So those who need to do emissions and have O/R will need to swap.
Brenspeed helped me out as well. However, I'm still not sure I would pass a sniff test because we worked around it. Fortunately we don't have those yet....when you have to pass the sniff test it's a whole new ballgame.
__________________
2007 Alloy GT Coupe/MGW shifter/C&L Racer CAI/JBA LT's/JBA catted H/Pypes M-80 race mufflers/Steeda HD engine mounts/LFP 17# driveshaft/FRPP 4.10s/Truetrac/Steeda Ultralite 18x9.5's with 275/40 and 285/40 Nitto NT555/Autometer DPSS shift light and gauges. Suspension: Steeda Comp Springs/GT500 Front CA's with Steeda X5 balljoints/Steeda bumpsteer kit/Tokico D-Specs/BMR adj upper & lower LCAs+relocation brackets/Hotchkis 3/4way adj swaybars/UMI Performance panhard.
Can't register a car to a po box in PA. States catch onto the loop holes eventually.
__________________ 06 Yellow GT 5 Speed. Pro 5.0 shifter, Steeda HD rear sway bar with billet end links, Steeda front sway bar, Steeda UDP, BMR combo adj LCA's, BMR combo UCA, BMR adj panhard bar, K&N CAI, Steeda strut tower brace, Magnaflow Magnapack cat back, BAMA chips SCT, Ford Racing 4.10's, Sequential tail lights, Shorty antenna, Silverhorse Racing rear center cover.
