Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-14-2009, 10:00 PM   #1
out_of_conDROLL
Send a message via AIM to out_of_conDROLL
Default Throttle Body vs. Underdrive Pulleys
I am just trying to decide between the two for my next mod. Each seem to give the same amount of hp but the TB will lower my mpg and the Pulleys ruin my air conditioning. Or should I get some Delete plates? The video in my sig is what I have done so far.
__________________
Veni, Vidi, Velcro.....I came, I saw, I stuck around
JLT II CAI
Xcal2 w/ Brenspeed tune
JBA Long tubes
JBA H-pipe
SLP Loudmouths
http://www.youtube.com/watch?v=dg4NX27YTlc
out_of_conDROLL is offline   Reply With Quote
Old 10-14-2009, 10:14 PM   #2
mb2
2005 Ford Mustang
mb2's Avatar
4.10s. .
__________________
Borla Stingers, Pypes O/R H,JLT & SCT X3 93 Tune,FRPP 4.10's, Ford Racing K-Springs, 14 in Shorty Antenna, C Series Window Louvers, Eleanor Hood, 18x9 18x10 fr500's
2005 Windveil Blue GT
2005 Mineral Grey V6 Mustang Coupe - Sold
mb2 is offline   Reply With Quote
Old 10-14-2009, 10:23 PM   #3
Nuke
2007 Ford Mustang
My Garage
Nuke's Avatar
Vehicle: 2007 GT
Send a message via AIM to Nuke Send a message via Yahoo to Nuke
Who says UDP's ruin your A/C? Not according to the forum members. Plus, UDP's are more of a sure couple of ponies compared to an aftermarket TB on a NA or non-modified-internally S197 4.6L. And aftermarket TB's have been known to be an install nightmare to an unacceptable (IMO) population of those that HAVE installed them.
__________________
Rick
07 GT Prem: Alloy, MT, 3.55's, Steeda CAI w/Brenspeed tunes, FRPP Stingers, 275/40/18 Goodyear Eagle F1 A/S on SVT Cobras (OE GT500's), 14" shorty, Wheelskin side scoops & qtr window louvers, A-H rear window louvers, SHR honeycomb blackout panel, Sequentials, Hella Optilux Extreme XY fogs, Silverstars
06 V6: Legend Lime, Pony Package, 14" shorty, Sequentials, Hella Optilux Extreme XY fogs, Silverstars
Nuke is offline   Reply With Quote
Old 10-14-2009, 10:28 PM   #4
04sonicbluegt
2004 Ford Mustang
04sonicbluegt's Avatar
Vehicle: 2004 mustang GT
i know i've got a new edge, and maybe i don't apply. but i have both, and honestly the UDP's where tougher, and the TB and plenum was a breeze. i got a great deal from ebay.
__________________
PS3, Xbox 360's for sale. pm me if interested
04sonicbluegt is offline   Reply With Quote
Old 10-14-2009, 10:46 PM   #5
S197winstang
S197winstang's Avatar
Vehicle: 2006 Mustang GT
Yeah, save your $ no way to the TB. Go with the UP if you dont plan on going FI. I would get the 3.73 or 4.10 gears over either one. Good luck.
__________________
Brenspeed V3 Vortech SC, Brenspeed custom Tune- (395rwhp 380 TORQUE) installs done by GTR the best stang shop in Cali, FRPP 3.73 gears, Bassani x-pipe, JBA shorty heads, X3, Spintech's Super Pro axle back, Steeda oil sep.
S197winstang is offline   Reply With Quote
Old 10-14-2009, 10:58 PM   #6
Tylus
Tylus's Avatar
Vehicle: 2009 Bullitt #6451
+1000 on the gears
otherwise, run the U/D pulleys. the throttle body is a spurious gain and has lots of issues to get them tuned.
alternator wise, it will be spinning slightly slower than normal at idle. if it concerns you, use your tuner to bump idle up 100 RPM to offset the lower RPM
U/D pulleys WILL NOT HARM your alternator. the only effect will be a slightly lowered charge capacity while at IDLE only. it will operate as normal otherwise.
get gears instead. about $100-200 more overall, but you will see actual real world results, and the butt dyno will be very happy
__________________
2009 Bullitt
3.73 Gears | FRPP CAI & Tune | FRPP Strut Tower Brace | Hurst Short Throw
Blackout Panel | Billit 9mm Door Locks | UPR Fuel Door | Custom Shelby Hood Pins
Currently deployed...see y'all on the flip side
Tylus is offline   Reply With Quote
Old 10-15-2009, 01:14 AM   #7
jz
jz's Avatar
Vehicle: 06 mustang GT
Gears have been my best upgrade to date. I've read way to many negative posts about TB's to even consider it.
__________________
06 Yellow GT 5 Speed. Pro 5.0 shifter, Steeda HD rear sway bar with billet end links, Steeda front sway bar, Steeda UDP, BMR combo adj LCA's, BMR combo UCA, BMR adj panhard bar, K&N CAI, Steeda strut tower brace, Magnaflow Magnapack cat back, BAMA chips SCT, Ford Racing 4.10's, Sequential tail lights, Shorty antenna, Silverhorse Racing rear center cover.
jz is offline   Reply With Quote
Old 10-15-2009, 01:43 AM   #8
66FB06GT
Vehicle: 06 Mustang GT & 66 Fastback Mustang
I would do UDP's long before the TB. Gears are probably your best bet, but will cost more. I really like my Coast aluminum driveshaft, but again that is quite a bit more than UDP's or a TB.
If you race your car you would probably be best served getting some suspension mods over any of these.
__________________
FastbackMustang.com
66 Fastback Mustang - 302, C-4, 8" w/3.80 posi
06 Silver GT - 5spd, JLT, BamaChips 93 Race, 3.73, Coast DS, MAC LT's w/ Prochamber, FRPP GTA's, Steeda UDP & Delete Plates, CHE Anti-Squats/DS Loop/K-member brace, BMR LCA, Roush Rear Springs, Black FRPP FR500, Nitto 555
66FB06GT is offline   Reply With Quote
Old 10-15-2009, 06:31 AM   #9
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
Vehicle: 2006 Ford Mustang GT
Quote:
Quote:
Quote:
Originally Posted by Tylus View Post
+1000 on the gears
U/D pulleys
what they said!
__________________
2006 Mustang GT with Cervinis Kit
Whipple Crew member
H.O. S/C 465 RWHP and 440RWTQ
First online article about my car! check it out!
http://www.examiner.com/examiner/x-8811-Detroit-Sports-Car-Examiner~y2009m5d30-Jason-McGuires-2006-Mustang-GT
http://www.cardomain.com/ride/3342086
www.mocsem.com
mygt500 is offline   Reply With Quote
Old 10-15-2009, 08:11 AM   #10
usc49erfan
2006 Ford Mustang
usc49erfan's Avatar
Vehicle: 2006,Ford, Mustang GT
i have them both and all i can say is that i wish i had the $300 back from the throttle body
__________________
2006: performance Jba Lt and O/R H, bbk cai, udp, and tbi, frpp 3.73, bamachips tune,
apperance eleanor hood, side scoops, and 1/4 louvers, roush spoiler, black 12" stripes, agent 47 mirrors, 20x9 and 20x10.5
1990:347 stroker, msd, cam, mac shorties, short throw, o/r h, flow 40s
usc49erfan is offline   Reply With Quote
05, 2006, body, ford, forums, gt, lower, mpg, mustang, pulley, pulleys, racing, stock, throttle, underdrive
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
