Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-19-2009, 02:44 PM   #21
thunderhorse
thunderhorse's Avatar
Vehicle: 2002 Mustang GT
F1 transmissions shift faster than a true manual, but to me, that takes the fun out of driving. Driving a manual is a pleasure, yes even in traffic and hills. You have ultimate control over your vehicle 100% of the time. I will never buy a car without 3 pedals. I know people that didn't buy the Nissan GTR because it didn't come in manual... if I had that money I wouldn't either. Even if you go on youtube and listen to an automatic transmission... IMO not nearly as savage as ripping shifts off in a manual. The only cars that sound good with F1 transmissions are from Ferrari and Lamborghini.. but even so, I'll take the 6spd please. There have been a million instances when I've been driving my SUV, especially on long road trips, that I wish I had a manual... obviously 95% of the time in a SUV or truck autos are just fine, but still, that's an instance where I really could have used a fast downshift for a pass.
Just my 2 cents =P
__________________
Exhaust Vid - http://www.youtube.com/watch?v=CCRPr3fzHuw
KB Raw Footage Vid - http://www.youtube.com/watch?v=8iUPIOSLe-w
Kenne Bell 2.1 IC @ 9PSI
thunderhorse is offline   Reply With Quote
Old 10-19-2009, 02:49 PM   #22
Riptide
Riptide's Avatar
Vehicle: 2006 GT
Less drivetrain loss as a general rule is still true with the manual. The difference is minimal. Probably on the order of a few percent.
Unless you power shift hard you will probably never match the automatic.
For drag racing the automatic is the way to go if that is the primary purpose for the car.
__________________
2006 GT, Manual
JLT2 w/91 Tune
FRPP 4.10, Steeda LCA
MAC Boomtubes
Goodyear 255/45/18, 285/40/18
Riptide is offline   Reply With Quote
Old 10-19-2009, 02:51 PM   #23
Derf00
Quote:
Originally Posted by Tylus View Post
stock for stock...a 5 speed is faster hands down off the line, and at the top end
the OEM torque converter and tuning makes the auto lose quite a bit of "oomph" off the start.
but once you are in 2nd gear or higher, it's all about the drivers.
in the mid gears, the auto has more advantage since you can keep your throttle planted and it takes care of the shifting. not many manual drivers can do the same while shifting...I've been trying for years and still can't do it.
in the upper end, the auto suffers. the torque converter and the tranny itself eat more HP than a stick does. so it takes more input from the crankshaft to achieve the same results a manual can get.
now, simple tuning of an auto...in terms of speed, that will put it on par with a stickshift. it can really firm up the shifts, and make things crisper and faster...which = faster.
adding a higher stall torque converter + 4.10 gears...and you'll have a automatic that many sticks would be hard pressed to keep up with.
and all of that is assuming you drive in "D" only. if you take your auto and run it up the gears, they respond even better. it's a facet of their programming. if you put it into 1st gear, the solenoids don't build up pressure for the shift into 2nd gear. this results in more power directed to the 1st gearset. just remember to pop it into 2nd gear about 500 RPM before the redline so enough pressure is developed to shift it prior to hitting the rev limiter.
my 03 GT was an auto.
could do an anemic burnout in Drive, and the occasional 2nd gear scratch.
but place it into 1st, and that thing was a tire shredding monster. when I manually shifted to 2nd, it would lay it sideways.
I don't recommend you do this often though, it is harder on the transmission than just normal driving is
all things being equal, I'd still take a stick shift again. I just get bored with an automatic. but I do see their appeal in horrible traffic. guess it just depends on how much & where you drive it
Totally disagree with you about off-the-line. New stangs (s197) have 5 speed transmissions just like the manuals. The first gear in auto is shorter than the first gear in the manual so the oomph is just the same. That's why the newer stangs are identical in the 0-60 mph and maybe .1 slower and 1mph slower in trap speed (auto) vs previous generations where the Manual was just plain faster.
I can do crazy burnouts in my auto in 'D' or '1st'. I just need to make sure TC is off
The one place where I miss the manual tranny these days is the twisties. Although here in AZ there's not much near where I'm at. I have to drive about an hour to the mountains in the east valley to get twisties. In CA just outside my door there were windy roads.
Derf00 is offline   Reply With Quote
Old 10-19-2009, 02:56 PM   #24
Riptide
Riptide's Avatar
Vehicle: 2006 GT
The ultimate transmission is one that isn't yet available in the mustang.
A true dual clutch transmission with paddle shifters. That will destroy any automatic or true manual transmission out there right now.
Sadly, AFAIK, will not be an option on the 2011.
__________________
2006 GT, Manual
JLT2 w/91 Tune
MAC Boomtubes
Old 10-19-2009, 02:58 PM   #25
Pete_Rockett
Vehicle: 2008 GT
My Bamachip tunes give my auto a shift that snaps my neck under full throttle. Instantaneous and HARD!
__________________
2008 GT, auto, Windveil Blue, Steeda CAI, Bamachips tune, 3.73 gears, more to come..."I haven't smiled this much in a long time!"
Pete_Rockett is offline   Reply With Quote
Old 10-19-2009, 03:05 PM   #26
Jizz
Quote:
Originally Posted by REDFIRE_GT_BEAST View Post
and as far as losing horsepower you lose more horsepower with a manual shifter
Wait, wut?
Jizz is offline   Reply With Quote
Old 10-19-2009, 03:08 PM   #27
Tylus
Tylus's Avatar
Vehicle: 2009 Bullitt #6451
Quote:
not quite
stock Auto's have a lag in 1st gear. It's just a function of the low RPM + stall converter.
hell, the 1st gear in my Expedition 6 speed is deeper than the granny gear in an old 4 speed F-350.
wish it could do a burnout...that would be pretty sweet
once out of 1st gear, the automatic then shows it's performance potential with the ability to shift quickly and keep 100% throttle.
vs. a Manual which requires throttle release, and the shifting is slower
that is why the automatic & manual have the same trap time roughly.
the auto can quickly make-up the initial loss, and the stick has to slow down for the shifting. it all equals out
it all depends where you use it.
An automatic is hands down quicker when modified. no question about it. swapping in gears + a line lock + a higher stall = one quick damn car
but IMO, pure fun factor of a stick FTW. and not many people go through all the necessary mods to make an auto quick...cause it can get expensive
__________________
2009 Bullitt
3.73 Gears | FRPP CAI & Tune | FRPP Strut Tower Brace | Hurst Short Throw
Blackout Panel | Billit 9mm Door Locks | UPR Fuel Door | Custom Shelby Hood Pins
Currently deployed...see y'all on the flip side
Tylus is offline   Reply With Quote
Old 10-19-2009, 03:10 PM   #28
Tylus
Tylus's Avatar
umm...what you been smoking?
__________________
2009 Bullitt
Old 10-19-2009, 03:19 PM   #29
d_ames117
2007 Ford Mustang
Quote:
Originally Posted by Nuke View Post
You DRIVE a manual. You ride in an auto.
My thoughts exactly. My manual has turned into my DD for a little while and I have some stop and go traffic on the way home. It just makes your left leg a little stronger.
Ames
__________________
'07 Vista Blue GT/CS
d_ames117 is offline   Reply With Quote
Old 10-19-2009, 03:54 PM   #30
grampa_stang
grampa_stang's Avatar
Vehicle: 2007 GT Coupe
It's the manuals race to lose. And..sadly, most do. Most try to launch too hard and end up spinning the tires and the race is over by the time I hit 2nd. I've only lost to 1 manual....and that was at the track where he had DR's. He totally out launched me, jumped a quick car length. I stayed on his bumper till the end.
Stock for stock, the manuals have the advantage due to their higher RPM launch capability.
__________________
'07 GT - AT / IUP / Charcoal int / Carbon fiber dash
JLT / SCT Xcal 2 / Bama 91 Race / Eibach Pro / 3.73's
Tint / Shorty / Sequentials / Cervinis side louvers
BFG G-Force SS A/S P255/45-18 / ADR Wheels
BoomTube Crew Member
13.66 @ 100 (DA 4300')
grampa_stang is offline   Reply With Quote
05, 2005, auto, automatic, drag, faster, gear, gt, manual, mustang, oil, put, racing, shift, stick
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
