Wow thanks guys all that info will really help alot... wish me luck
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
Silver 2007 GT premium 3.31 gears 5 speed C&L intake and Brenspeed 93 tune. BBK ceramic coated longtube headers with an X pipe no cats into Boomtubes, aluminum drive shaft, underdrive pullies, hurst short throw shifter, Black FR500 18's with nitto 555.
Having done my own: 4+hours to do both springs and LCAs. Then I'd lower the car and take some measurements before putting the new panhard on. The panhard's length will need to be adjusted after the springs go on, so why not just do that second. The panhard swap will take under 2 hours. Most s197 rear sway bars have their bolts installed backwards from the factory so you'll have to lower the sway bar to access the panhard bolts the first time.
Oh and a quick tip: while you're out buying a big-boy jack and some real jack-stands, do yourself a favor and pick up some PB Blaster. Those LCA bolts can be a bit sticky....
hey guys well i decided to change my oil(royal purple and fram filter) and just do the panhard bar for now...i wish i went with a not adjustable pan hard bar though, now i need to go get lock tight for the adjustable part and Is it just me, the stock PHB seemed alot sturdier then the BMR adjustable pan hard bar. Almost like it might bend or snap where it adjusts?
__________________
Tylus: by myself in the driveway on jackstands, I'd say 4 hours is about what I spent on the lower control arms and the rear springs the first time I swapped them.
To the OP, you'll be glad you got that adjustable bar after you lower the car. Trust me.
