Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-31-2009, 05:28 PM   #11
Fort LiquordaleGT
Vehicle: 06 GT
Yes, the trans can whine even while in neutral if the car is moving. The shaft in the trans is still moving when the car is moving, putting it in neutral only disconnects it from the engine, not the rear and drive shaft.
If you want answers do this..
Put in N turn off car and coast and see if it makes the noise. If it does we can eliminate the clutch being the problem. That leaves the tranny back.
Disconnect the drive shaft, push the car, if you get a whine, it's the rear. No whine means it's the tranny.
If I had to guess, it's your tranny. 6500 is a massive amount of power to put into 2nd gear. Did you quickly get out or did the engine redline and shut the fuel off and lock the wheels up?
Fort LiquordaleGT is offline   Reply With Quote
Old 10-31-2009, 06:48 PM   #12
TorchRed04GT
Vehicle: 2007 Ford Mustang GT/CS
I quickly got out of the gear, it might of axle hopped a couple of times, but it did not lock up the rear. Well, this does not sound good. I am super pissed at myself. So if the tranny is shot how much am I looking at for a tranny rebuild?
__________________
2007 Mustang GT/CS
H&R SS, BMR panhard bar Pypes MM, JBA LT's & o/r H, Steeda CMDP, JLT, Comp Mutha Thumpr's, FRPP 4:10's, Steeda shifter, Brenspeed tune
TorchRed04GT is offline   Reply With Quote
Old 10-31-2009, 07:05 PM   #13
rford426
Vehicle: 2005 Mustang GT
Keep us posted man good luck!
__________________
2005 Black GT Manual
Steeda CAI-SCT XCAL-Pypes O/R X pipe-Pypes Mid Mounted M80s-Red Top OPTIMA-HurstSTS-Tein Tech S-AVIC f900bt-Back up Camera-20" Black Chrome FR500s-GT500 FRONT/REAR-Factory GT500 6k HIDS-3k HID Gt500 fogs-
303rwhp/319tq
rford426 is offline   Reply With Quote
Old 11-01-2009, 01:03 AM   #14
TorchRed04GT
Thanks I will more than likely end up replacing the gears, differential, and going with moser 31 spline. At that point, I will address the tranny issues if there are any. This is going to be one expensive mistake. Oh well, at least I have all winter to get it done lol.
__________________
2007 Mustang GT/CS
Old 11-01-2009, 09:30 AM   #15
rford426
^BTW Your car looks amazing it all flows togg perfect...Nice look!
__________________
303rwhp/319tq
Old 11-01-2009, 09:40 AM   #16
Fort LiquordaleGT
Vehicle: 06 GT
You may not need a new tranny, it all depends on what if any you broke in it. I had my old 5.0 tranny rebuilt for 500 bucks..
Old 11-01-2009, 10:35 AM   #17
pascal
S197 Section Modder-ator
pascal's Avatar
Vehicle: 06
Quote:
On a 5.0 it's a T5, which is a hunk of schit (no offense).
It will be more expensive to go through the Tremec he has now.
I say it's a good time to go 6spd if his current tranny is waxed.
However, with his 4.10 gears, the 1st gear might be useless...
__________________
pascal is offline   Reply With Quote
Old 11-01-2009, 11:25 AM   #18
Simon1
2006 Ford Mustang
Vehicle: 2006 Mustang GT
Quote:
You already have 31 spline axles. No need for anything more for 99% of us. IF they are damaged, which I wold put money on they are not, then an upgrade would not cost any extra than OEM pieces.
Your differential and gears are probably okay. Usually when something like that happens it will break teeth off in the ring/pinion if the diff does get damaged.
I would lean towards a transmission issue.
__________________
Motor Built and tuned by ST Motorsports
470/490 91 octane 10 psi
530/550 100 octane 12 psi
11.7 @122 with 1.78 60'
I'm not a member of any "Crews"
Simon1 is offline   Reply With Quote
Old 11-05-2009, 10:22 PM   #19
VanWilder
Vehicle: 2005 Ford Mustang GT
UPDATE!!! It ended up being the differential and gears...both getting replaced today...I don't have a clue exactly what or how they were damaged just know those were the two things that needed replaced...Im sure TorchRed04GT will give an update on details sometime soon...no tranny issues tho so thats a plus
__________________
2005 Mustang GT black 5-speed(13.39 at 101.51 stock)
BMR 2in. lowering springs, UPR adj. panhard bar, UPR O/R X-pipe, Flowmaster, JLT CAI w/ BAMA 93 race tune, Vredestein 275/35/18 Front and 295/35/18 Rear and some 26x11.50-17 Mickey Thompson ET Streets for the track
12.76 @ 108.88 Now
New Mods: JBA LT Headers, O/R H-Pipe, FRPP 4.10 gears, CMVC Delete plates, Mutha Thumpr cams w/ Tillman Speed 93 All-Out tune
12.41 @ 107.89
VanWilder is offline   Reply With Quote
Old 11-05-2009, 10:24 PM   #20
pascal
pascal's Avatar
Vehicle: 06
Glad your tranny is safe.
__________________
2007, broke, car, diagnosis, gears, make, mustang, neutral, speed, transmission, whine
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
