Sponsored by:
Sponsored by:
For those thinking of high HP - read this!
Old 03-19-2006, 03:02 PM
spyder7724
spyder7724's Avatar
Default RE: For those thinking of high HP - read this!
and nobody understood why i have done everything else but a s/c or turbo. and why i'm a fan of staying N/A. thats not to say that high hp n/a cars don't need fuel system and engine upgrades but everything is not as extreme. i want to run 11's n/a. i know it can be done justin already did it. i have been racing and around it all my life. the easiest way to go fast is reduce weight and have a properly setup suspension. this alone can give performance gains equal to or beyond power adders. like mine my auto has been so far 12.60's...my engine is stock from the t/b to the oil pan. after some more tweaking with gear ratios and tuning i believe 12.40's are in the near future. now i'm getting close and i haven't even began to think about the engine yet. hopefully by the end of the season i'll see my 11.99 with a stock motor once the entire combination is optimized. then i can set a new goal. 10's with a stock shortblock n/a? maybe.
spyder7724 is offline
Old 03-19-2006, 03:07 PM
MusiccityGT
MusiccityGT's Avatar
ORIGINAL: spyder7724
I am right there with ya brother! These thoughts about power adders roll through my brain and then someone gernades a motor.
MusiccityGT is offline
Old 03-19-2006, 04:11 PM
GJP05
GJP05's Avatar
Hey CK what did your rotating assembly come with? Mine came with rods, rod bolts, dished pistons, rings, main studs, head studs, rod bearings main bearings, and crankshaft for $1965.
GJP05 is offline
Old 03-19-2006, 04:30 PM
zanemoseley
zanemoseley's Avatar
Isn't 14psi on stock internals just asking for it though. I thought if you're running 8psi or under you dont' have to worry much about the stock stuff.
zanemoseley is offline
Old 03-19-2006, 04:46 PM
dkano
dkano's Avatar
I'm right with you too, one for staying N/A and the other because you also have an auto, so I always look for any updates from you on times or any upgrades either here or on other boards. I know I'm not as good a driver but I'll be getting some practice soon. I've never ran the 1/4 mile at a track before, plan on going down to Atco in NJ soon though, have to check their schedule.
Gotta love CK for being out there doing all those things, then coming back and sharing the info too. [sm=signs003.gif]
dkano is offline
Old 03-19-2006, 05:05 PM
Tres Wright
Tres Wright's Avatar
==and nobody understood why i have done everything else but a s/c or turbo==
==These thoughts about power adders roll through my brain and then someone gernades a motor. ==
Chevykiller stated that he has been running over 500 hp on stock lower end for over a year without problems. His post is intended for the truly hardcore that are after 600+ hp (which is where he's heading with his new motor). Throwing a power adder on there isn't going to get you guys up to those power levels if it's set up with the recommended PSI. The tune is really critical with power adders, if you don't get a proper tune you're going to run lean and that may blow the motor. If you read freefallpat's post, he was running a whopping 14 psi and did not dyno tune it. That's way beyond the recommended parameters. It's truly unfortunate and I'm sorry to hear it happened, but I would not be afraid to run a power adder based on posts like that.
Tres Wright is offline
Old 03-19-2006, 05:57 PM
XLeatherNeck
XLeatherNeck's Avatar
So basically if you wanna make crazy horsepower, you better have the funds to purchase a short block with forged internals.
XLeatherNeck is offline
Old 03-19-2006, 06:09 PM
freefallpat
freefallpat's Avatar
ORIGINAL: Tres Wright
Would it be possible to put a 460 BIG block in a mustang 05? Hell Ford racing make one that is over 600hp N/a?
freefallpat is offline
Old 03-19-2006, 06:14 PM
hawgman
I ♥ Acer
hawgman's Avatar
ORIGINAL: chevykiller
I get better deals than most (Bear that in mind) and here's what I've had to shell out so far...
302 stroker kit with rods, pistons, crank, and assembly - $2200, Valve train and springs kit - $1700, Comp cams - $650, -8 fuel lines/60 lbs injectors/injectors adapters/fuel rails - $1500, head work - $800, Charge motion delete plates - $300.
Not trying to sound like an *** or anything, but where is the "better deal"? Those prices are pretty much dollar for dollar the same as what anyone can get from SHMs web site.
I do have a question for you, and a couple of comments.
How much have you investigated going with a stroker setup on this block? Reason I ask, is because I have been kicking around the idea also. And I have heard from a couple of different sources that if it done with what most everyone sells on the market currently that after 20k or so miles the sleeves start loosening up in the block because of the length of the rods people are selling with the stroker kits.
My comment is on the CMDPs. I am actually pretty surprised that was the cause of the engine failure. What surprises me about it is I pretty much assumed that anyone that went forced induction just automatically installed CMDPs. Seems sort of anitproductive to put on a power adder and leave an intake restriction on the motor.
As for the fuel system, 100% agree with you. Upgraded fuel lines and injectors are a must. Get in to high HP and fuel rails and possibly a pump change ( I am kind of anit BAP ) are going to be very necessary. But everyone should note that fuel system upgrades on a returnless fuel system are a PITA so be prepaired.
hawgman is offline
Old 03-19-2006, 07:48 PM
Tres Wright
ORIGINAL: freefallpat
I'm sure anything is possible I saw a picture of a V6 'stang that had a Ford GT wedged in it, that's the kind of stuff that gets you thinking crazy thoughts
Quick Reply: For those thinking of high HP - read this!
