My experience installing the AEM “Brute Force” CAI…
RE: My experience installing the AEM “Brute Force” CAI…
ORIGINAL: RW06stang
Looks very good man. Hmm...... how would that do with my Nitrous?
[IMG]local://upfiles/33407/742CD5055F7440C2BAC588F60B3CB503.jpg[/IMG]
ORIGINAL: zjdoran7
How much for the shaker hood + paint?
ORIGINAL: Orion_240
Thanks Prof! It looks much better now. I just had a pet peeve with that old intake pipe's red not matching the car's red! ;-)
I noticed it looks like you had a silver OEM air filter cover. Was that a slip-on cover or what?
The other question is what exactly does the Shaker intake do?
The Shaker - as designed, acts as a pressurized "Ram Air" air system when you’re moving faster then 20mph. The kit encloses the factory air box so pressure can build up giving your engine more direct cool air.
Installing the AEM, I re-engineered the ductwork from the Shaker to force cool air into the heat shield area of the intake.
ORIGINAL: hawgman
Thank Gawd you finally got rid of that fugly red spray painted stock intake tube.
In case you are wondering...
WHAT MODIFICATIONS did I have to make to the Shaker for my AEM CAI?
First - - had to reshape the front mounting bracket which attaches to the front of the Throttle Bore Housing to allocate for the additional distance created by adding the AEM Spacer.
Second -- Had to cut a hole for the MAF Wiring Access. The original access hole location would not allow me to reach the MAF in its new location on the AEM.
Third -- Had to take my dremel and cut a notch out of the side of the heat shield to allow access of the Cold Air Duct coming from my Shaker and entering the space of the AEM Intake.
Forth -- Trimmed the original Shaker Cold Air Duct so it would dump into the AEM Shield.
Here are some of pics of the finished Shaker / AEM Incorporation.
You can see the original hole for the MAF jack, and the new one I created.
Here you can see where I trimmed out the Heat Shield to create access for the Air Duct...
And the finished product...
Thanks Professor for the excellent write up. I want to do pretty
much the same thing and was wondering how you incorporate the
shaker and the CAI system (in a functional mode).
Professer Your engine is simply beautiful. There is no doubt in my mind that you are definately in the show car thing. Thanks for the illustration.
Mike...
I got the AEM from AEM...
You do NOT need a tune.. and it will NOT throw any codes... However, you can always get more benefit if you have a tune with a CAI.
I drove it a while with the tune I had already installed with my shaker, then ran by the shop that does my tunes and had it retuned.
