Last edit by: IB Advertising
Browse all: Interior Guides
- Ford Mustang V6 1994 to 2004: Why is Interior Rattling
Guide to diagnose trouble and recommended solutions
Interior Buzz/Rattle Locations/Fixes
Ok, after upgrading my stereo from the Skipper1000, my whole car seems to buzz and rattle. The worst offender seems to be the two window switches on the driver's side. If I simply lay my hand on the switches, the buzzing stops. The passenger side buzzes from the switch as well, but it's only one switch... so it's not as bad.
Somehow, the dashboard rattling is gone. I think they must've taken it off during the install and maybe fixed what was buzzing. I also have some rattling from the rear seat areas, too.
So I figured it would be a good idea to start a thread that listed all the places our car rattles/buzzes/shakes/etc and what people have done to fix it. If you have any inputs, reply to the thread and I'll edit this first post. I'll start:
- Window switches: Take out switch assembly and coat with clear silicone where housing meets the sides of the switch box (below armrest).
- Shift boot: Get an aftermarket shifter.
- Driver's door mirror: Need fix action
- Plastic trim behind the inside door handle pull: Take it off and add a thin dab of silicon to the back or stick on a piece of thin weatherstrip...re-install and its fine.
- Little plastic piece inside of the passenger door grab: Dynamat
- Plastic housing that goes over the latch on the trunk lid: Dynamat
- Somewhere behind center console at idle: Need fix action (I have this problem, too)
- Vents: Need fix action
We're getting there!!!
RE: Interior Buzz/Rattle Locations/Fixes
I have a buzz in my drivers door mirror when the base on the stereo gets going on a good song, or a DJ's deep voice. Also when I hit a bump just right.
Souncs like 50 bees in a beer can!
Ok, I figured out the solution for the window switches. It's not actually the switches themselves, it's the housing below them. There are four clips, you have to pry two on each side to remove the switch housing. Use silicone to coat where the switch meets the housing. Rattle gone!
@ProfessorWizard
Mine doesn't make any noise, but I cannot even see out of it when the music is even moderately loud.
@ProfessorWizard
The plastic trim behind the inside door handle pull rattles easily. Take it off and add a thin dab of silicon to the back or stick on a piece of thin weatherstrip...re-install and its fine.
The parking brake release button on mine vibrates pretty bad in the winter. Don't have a fix yet. If I could take it apart and add a stiffer spring, or possibly put a little thick grease in there it would go away. Anyone got an idea on this one? I know that's the spot because I can depress it lightly when I hear it and it goes away.
I had a consisten rattle under deep base from the little plastic piece inside of the passenger door grab. I popped the piece off and applied a couple small pieces of dynamat in there and reinstalled and the rattle went away.
The plastic housing that goes over the latch on the trunk lid, buzzed like a swarm of south american killer bees.
Few little strips of Dynamat and its quiet as a mouse now. But it was so annoying prior to fixing it.
ORIGINAL: flapjack
Heck make this a sticky, I like it.
