GT500 Brake Install
RE: GT500 Brake Install
ORIGINAL: cortc
The stock rotors are much smaller, you need to get the following...
1) Brembo calipers
2) Front 14" Brembo rotors
3) Front Brembo pads / Rear brake pads
4) Front dust shields (They come in a pair...)
5) Front caliper pad installation kit (This includes the pins and spring clip that hold the pads in place...)
1) Brembo calipers
ORIGINAL: androdz
What else did you need??? I am running 17 inch wheels and I just bought the gt500 breaks. Are you using the stock rotor??
Att. Andrew
Att. Andrew
Keep us posted on how you like the upgrade... WHat did the upgrade (with the Steeda lines) cost ya?
ORIGINAL: androdz
Att. Andrew
Att. Andrew
By the way, the GT500 factory Brembo brakes come out 10-15mm more than the Brembo aftermarket kit but do not require adapter plates...
It measured 47mm from the wheel mounting surface to the caliper face.
I measured the gt500 setup last night and it was within a couple mm of that.
I bought the Actual gt500 calipers on ebay. Here is the link.
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
Where can I buy what else I need any links??
Att. Andrew
Att. Andrew
Try Kevin Casey at
www.clevparts.com
Send him an e-mail at clevparts@aol.com.
In the subject line put the word "hotsheets gt500 brakes" or something like that. Tell him you need everything except the calipers.
But expect to wait about a month for everything at this point. But Kevins pricing is pretty good on most stuff.
DynoJoe also had some kits in stock. Not cheap, but in stock. I guess he was at MSRP or a little above.
http://www.dynojoe.com/
www.clevparts.com
musnicki
09-23-2015 07:11 AM
