Sponsored by:
Sponsored by:
Aftermarket wheels on an 07
Old 01-05-2007, 01:12 AM
blueherd02gt
blueherd02gt's Avatar
Default Aftermarket wheels on an 07
Does anyone know if a sct tuner will clear the tpms trouble light?
blueherd02gt is offline
Old 01-05-2007, 01:18 AM
06GT4RAD
06GT4RAD's Avatar
Default RE: Aftermarket wheels on an 07
Not sure but i do know if you got aftermarket wheels and they do not have the ports for the Tire Sensors then you will not be able to keep the light out. Your going to have to get wheels that accept the sensors or if your current wheels do then have the ones from the stock wheels installed.
Richard
06GT4RAD is offline
Old 01-05-2007, 01:35 AM
blueherd02gt
Yea I should have kept the fanblades on when I bought the car....I chose the lesser grade rims because I thoughtt I'd get aftermarket wheels....Look like I'll be buying wheels from the dealer. [&:]
Old 01-05-2007, 04:01 AM
mattblasi
mattblasi's Avatar
You do not need to buy the wheels from the dealer, you just have to take the sensor out of the factory wheels and install them in the new ones. If you whent up in size you will need larger bands but they are not that pricey. Any dealer can relocate the sensor from one wheel to another, and most wheel and tire shos can as well (and will probably be a little cheaper). If you do not fell like changing the sensor around you can have new ones instlled but then it starts to get even more expensive.
mattblasi is offline
Old 01-05-2007, 01:23 PM
06GT4RAD
06GT4RAD's Avatar
Exactly. I wasnt sure how the sensor were attached on the 07's but it sound like they use the Band style intead of the valve stem style.
Richard
06GT4RAD is offline
Old 01-05-2007, 02:14 PM
grbrorng07
grbrorng07's Avatar
The SCT will not clear that.I have the same problem and was hoping it would. A friend of mine that is a ford mechanic told me there was no way to turn it off.
grbrorng07 is offline
Old 01-05-2007, 03:04 PM
mattblasi
mattblasi's Avatar
There is no way to turn it off you need to swap sensors around, thats the only way I was able to get it fixed.
Old 02-07-2007, 06:23 AM
bcolem10
bcolem10's Avatar
I put mine in a sealed pvc tube with a valve stemand mounted it in the trunk, problem solved. Cheapest way to go.
bcolem10 is offline
jwog666
12-27-2021 08:09 PM
mungodrums
09-28-2015 10:54 PM
wraith777
09-28-2015 10:49 AM
folivier
09-26-2015 02:28 PM
09-24-2015 09:18 PM
Quick Reply: Aftermarket wheels on an 07
