Sponsored by:
Sponsored by:
Will fully syntentics 5W-20 oil be too thin in summer time?
Old 01-27-2007, 01:43 PM
Archion
Archion's Avatar
Default RE: Will fully syntentics 5W-20 oil be too thin in summer time?
ORIGINAL: NewMustang
ORIGINAL: Ford_Dude
Ford says 5w-20 so if your stock use 5w-20
if the engine is damaged tell ford to fix it
after the first summer you'll know
Thing is... Ford uses synthentics blend, I'll be using fully synthentics which is thinner than blend.
How is the same weight oil thinner? The weight and viscosity are measured and certified using the same tests. Who ever told you that is an idiot. If it is thinner than they could not legally call it 5w20.
Archion is offline
Old 01-27-2007, 01:45 PM
Archion
Archion's Avatar
ORIGINAL: LAK3RS
Is 10w30 okay?
no, 10w30 is bad, you could use 5w30 as that is really what the engine is designed to use, they just use 5w20 to meet epa fuel regs. 10w30 is too thick for the tolarences and seals. maybe after 100k, but not now.
Archion is offline
Old 01-27-2007, 02:42 PM
LAK3RS
LAK3RS's Avatar
So, do yall think that 5w30 would fit this car the best? Or just stick with 5w20...
LAK3RS is offline
Old 01-27-2007, 02:56 PM
lugnut
lugnut's Avatar
ORIGINAL: Archion
ORIGINAL: LAK3RS
Is 10w30 okay?
+1
Also the 4.6 engine has variable cam timing which is hydraulically operated for the mechanism to operate correctly you should always use a base 5W this will insure the oil flows as designed and insure you get maximum performance and gas mileage. If you are worried about summer temperatures then use a 5W-30 , 5W-40 or even a 5w-50 this would give you the protection you want. I would recommend you change these higher viscosity weight oils at least every 3-5k since they have more additives and will tend break down sooner then a 5W-20 oil.
lugnut is offline
Old 01-27-2007, 03:09 PM
07GT
07GT's Avatar
ORIGINAL: LAK3RS
Stick to the 5w20, don't worry about it being too thin, it was designed for it. I've ran thin synthetic oil on 70's style motors, raced the hell out of them, and still no problems. Bearings and cylinder walls checked good. Don't worry, be happy!
07GT is offline
Old 01-27-2007, 03:17 PM
Goldenpony
Goldenpony's Avatar
5W20 synthetic is fine in the summer. People that are afraid to use it are thinking in the 60's. The Dinooils of today are orders of magnitude BETTER than they were even 10 years ago. The Synthetics are even better. No worries mate!
Goldenpony is offline
Old 01-27-2007, 04:05 PM
BAMFstang
BAMFstang's Avatar
How about just stick with the manufacturers recommended weight of 5w-20.
They engineered the cars and probably know what they are talking about.
Full syn or syn- blend is fine, whichever you choose.
Ford puts a blend in from the factory.
BAMFstang is offline
Old 01-28-2007, 04:07 AM
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
Stick with 5w-20 as recommended....change regularly and forget about it!
mygt500 is offline
Old 01-28-2007, 04:20 AM
Ford_Dude
Ford_Dude's Avatar
the 5W is the cold weather test cert not the viscosity
the 20 is the viscosity so 5W-30 and 10W-30 are the same weight but with the 5W you can still crank the engine even if its -50F but if its 10W only about -35F
the viscosity is measured at standard air pressure and temp meaning sea-level altitude and about 75F
then for the W test the temp is lowered until it gels upan viscosity reaches a limit that was determined that an engine can still start with
if you don't care the brand of oil you use then you can find 0W-20 and with that you can drive the arctic circle
RP makes 5W-20 and thats what I use in TEXAS
Ford_Dude is offline
Old 01-28-2007, 10:10 AM
BlackPhantomGT
BlackPhantomGT's Avatar
http://www.bobistheoilguy.com/
BlackPhantomGT is offline
Quick Reply: Will fully syntentics 5W-20 oil be too thin in summer time?
