Does your 2005-2007 Mustang have a water leak? - Page 12 - MustangForums.com
Sponsored by:
Sponsored by:
Old 10-22-2015, 07:38 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Interior Guides
Print Wikipost
Old 07-22-2014, 10:49 PM   #111
tbear853
tbear853's Avatar
Never has yet ....
tbear853 is offline   Reply With Quote
Old 10-28-2014, 07:46 PM   #112
surfergirltg
Quote:
Originally Posted by BlueGTDreams View Post
My 2007 GT Coupe has been so called fixed 2 times for this passenger side water leak and is back into shop to fix again. This last time I was sick in bed and did not know it had leaked again and to my surprise the additional moisture inside the car with the windows up caused the center panels on my doors to become unglued and they just fell. I'm getting very tired of this repetitive repair along with the musky smell.
I have an 2005 mustang same problem noticed water leak in 2009 still was under warranty took it into the dealer and cost it me $150.00 for them to tell me the drain valve was blocked with leaves and dirt and they replaced the cabin air filter.Told me to try not to park under trees.I wish the dealer would have told me this before I bought my car .I wouldn't have bought the car because where I live there are trees every where.What a joke !!!! Ford SUCKS!!!!! Built ford though. Quality job #1 BULL**** !!!
surfergirltg is offline   Reply With Quote
Old 10-28-2014, 07:48 PM   #113
surfergirltg
Smile
Quote:
Originally Posted by tbear853 View Post
Never has yet ....
Consider yourself lucky.
Old 10-28-2014, 10:41 PM   #114
surfergirltg
Default Mustang leak
Quote:
Originally Posted by rcslcc View Post
I had a leak this weekend which destroyed all my computers and wiring for my 05 mustang. It has become a all points bulletin for all Ford Mechanics which means it is real close to a recall. I have talked to several departments and if enough of us call this number and complain it will become a recall. Then any personal cash you had to fork out will be reimbursed by Ford. The company name is NHTSA and the number is 888-327-4236. Just a note the repair for the work is $4000-5000 to replace everything including labor.
I saw this post and i have a 2005 mustang that leaks i know this is an old post .Canyou tell me if there ever was a recall on this leak issue and can i still call the 1-800 number.Please let me know ,Thanks
Old 10-31-2014, 10:31 AM   #115
SteveDwsn
SteveDwsn's Avatar
I thought I had a leak once, but I suspect my son didn't close the window all the way. On a side note, I live in the south and have noticed on rainy or even high humidity, not quite rainy days the ducting for the A/C will condensate and drops will fall on my leg. And yes, it is condensate, I have checked.
SteveDwsn is offline   Reply With Quote
Old 05-12-2016, 04:52 PM   #116
HFCA
not yet on my new to me 06, but boy does it drip lots of water after you move it after a rainstorm!
HFCA is offline   Reply With Quote
Old 05-13-2016, 12:26 PM   #117
surfergirltg
Default Water Damage
rcslcc7707440, Can you tell me if there ever was a recall from Ford for this water problem yet ?
Old 05-13-2016, 01:50 PM   #118
movielover40
Mine doesn't but it sure takes it's time coming out the bottom.
I'll go to car wash come home and it's dry underneath than check it 1/2 hour later and there is big puddle under the car.
movielover40 is offline   Reply With Quote
Old 05-13-2016, 10:54 PM   #119
2007 GT//CS
Had a leak,figured out the cow vent had gotten trash and leaves in it,cleaned it out now no leak.keep it clean and no further problems
2007 GT//CS is offline   Reply With Quote
2012 3.7 V6 water pump.. what's the trick? eastexsteve 3.7L V6 Technical Discussions 1 12-04-2015 06:41 AM
91 5.0 mustang Clunking in rear end? Exhaust leak? 91StangOwner 5.0L (1979-1995) Mustang 5 08-21-2015 12:34 AM
Ford Leaks Shelby GT350 Supplement Booklet MustangForums Editor Mustang News, Concepts, Rumors & Discussion 0 08-11-2015 04:43 PM
Just swapped motor exhaust want fit daytooday Motor Swap Section 2 08-11-2015 10:22 AM
exhaust leak at Crossover? 11GTBlu 5.0L V8 Technical Discussions 2 08-10-2015 06:56 PM
05, 2005, 20052007, 2007, convertible, ford, gt, inside, leak, leaking, leaks, mustang, mustangs, rain, water
