Sponsored by:
Sponsored by:
TRACTION CONTROL LIGHT
Old 02-10-2007, 01:29 AM
RANDY SANDOW
RANDY SANDOW's Avatar
Default TRACTION CONTROL LIGHT
I Started my gt vert tonight for the first time in about 2 and a half weeks to warm it up as it is frigid cold here. After starting, the check traction control light came on for a split second and went off and the odometer appeared again. What doyou think? The light is no longer on.
RANDY SANDOW is offline
Old 02-10-2007, 01:34 AM
Stoenr
Stoenr's Avatar
Default RE: TRACTION CONTROL LIGHT
You mean where it says off? Mine always stays on for the 1st few seconds after startup, thats normal.
Or you mean the little squiggly burnout icon my the speedo? [sm=gears.gif]
Stoenr is offline
Old 02-10-2007, 01:38 AM
PROMETHEUS PRIME
PROMETHEUS PRIME's Avatar
Well traction control warning lamp uses the ABS and instrument cluster modules. So if it saw a fault for that one instance it should have set a code. I would take it in to the dealer and have them check.
PROMETHEUS PRIME is offline
Old 02-10-2007, 01:17 PM
NyFordTech
NyFordTech's Avatar
Normal operation, any fault with the abs or traction control system would have a flashing or steady light.
NyFordTech is offline
Old 02-10-2007, 01:47 PM
RED121572
RED121572's Avatar
I tried to start a thread just like this last week and got no response.I saw the same lights on my dashwhen the carwas brand new. The dealer reset the code and everything has been fine for over a year. Last week, the lights reappeared on my way to work one morning. The lights will come on and stay lit for a few key cycles.
RED121572 is offline
Old 02-10-2007, 02:10 PM
edgespeeder06
edgespeeder06's Avatar
lol mine comes on almost everday when i leave my block, they threw so much salt and sand here that it looks like a beach, and i burnout and create a dust storm lol
be reminded, NJ hasnt seen a real snow storm this year and yet theres salt everywhere, can't even clean my car because everytime someone drives by, they create a dust storm that sticks to my paint
edgespeeder06 is offline
Old 02-10-2007, 02:11 PM
edgespeeder06
that picture was right after the body shop work, washed here 3 times and within a day she was all covered in dust
Old 02-10-2007, 02:37 PM
vb101
vb101's Avatar
My Mustang had the traction control light come on a few months ago, though it stayed on all the time. I knew what it was and immediately got it fixed. It was a wheel speed sensor that had gone bad. Every car I've had with ABS/TC has had a wheel speed sensor go out at some point. It's something to check.
vb101 is offline
Old 02-10-2007, 05:48 PM
TPony
TPony's Avatar
Mines turns on for a second, then goes away. Did not think it was a big issue....hmm.
TPony is offline
Colin Ringle
09-15-2015 09:27 PM
09-08-2015 11:50 AM
amandahchase
09-03-2015 10:09 AM
iculookin
09-02-2015 12:34 PM
Quick Reply: TRACTION CONTROL LIGHT
