Rear Seat Removal
RE: Rear Seat Removal
It's rediculously easy.
Your rear seat cusion (where your butt goes) simply pops out of the car. There are two clips you have to press down to get it out. The clips are located just under the front edge of the cushion, one on each side. Push them and then pop the cushion out. You will then be able to see the bolts which hold in the seat belts, the hinges for the seat backs, and so on.
It is MUCH more than 15 lbs.
The seat cushions are about 10-15 lbs...but the belts are heavy. It's a hair under 50 lbs if you remove everything: seat cushions, belts, and child-seat mount brackets. The belt retract mechanisms are very heavy.
+1 on what Al said!Ive been hearing people say its only 10-15lbs when I first said I wanted to do mine.....I got tired of argueing with people!So Im glad someone else knows the facts!
ORIGINAL: CrazyAl
