Motive Ring/Pinion for 05 ?
Does anyone know for sure if the current 8.8" ring and pinion gears offered by Ford as well as others such as Motive, will work in the 05 read end ? I would like to order some 4.10 gears next week, but need some feedback first.
RE: Motive Ring/Pinion for 05 ?
I spoke with Ford Racing - they ARE the same. So I have order some 4.10 Motive Gears and install kit.
I have an AUTO so once they are in, I will update everyone on the ride after install.
Off the line, the stock GT with an Auto now puts you back. The shift from 1st to 2nd is very quick - and when it does - it shifts hard everytime. When you hit second, you stay about 4000rpm and hit 6000 very quick. I will be running it harder today to get a better feel.
But from what I can tell, the RPM Range is Perfect for these gears.
Note: On the highway, I was driving at 65mph and 2000 RPM in OD. Not too bad for 4.10 gears
