Corsas + off-road h-pipe = LOUD (w/ video)
I put on the pypes off-road h-pipe yesterday and my first impression was HOLY CRAP it's loud!!
Idle sounds great. It's deeper and louder than with just the Corsas.
WOT is just plain deadly sounding.
The volume of the exhaust note is fine by me, but my only concern is the tone of the exhaust note. It changed a lot more drastically than I expected. At certain times it almost sounds like it's straight pipe all the way down. Tomorrow I'll be getting under the car to check all the bolts to make sure everything is tight (supposed to do this after 50 miles or so i think). I'll also be checking for leaks. I think one of the pipes on the driver's side is rubbing one of the little heat guards so I'll have to look at that too.
Overall i'm happy with it but i just wish i hadn't lost that deep grumble it had at low speeds (under 30 mph). The gumble is there at idle, when coasting, and when using cruise control but when i'm on the gas (no matter how softly) it sounds kind of raspy (best way I can describe it). There is more interior noise but that's to be expected. It's almost not noticable when cruising at a constant speed (65-70).
I'll have videos from inside and outside the car tomorrow.
RE: Corsas + off-road h-pipe = LOUD
Here are a few vidoes. It was hard to get a good WOT video since it's kind of wet outside. I'll get some better videos when it dries up around here.
I checked all the bolts today to make sure they're all tight and they are. I also found what was causing the vibration and fixed that. It was the arm coming off the passenger side part of the H-pipe that goes into the gromet...it was pushed to the outside and rubbing a bolt. I did notice after starting it and checking for leaks that there is a slight leak on both sides where the header fits to the flange on the h-pipe. It's not making a leaking sound (pst pst pst) but I can feel it. Has anyone else noticed this before?
WOT from outside:
http://www.youtube.com/watch?v=nISt2ZoKVDg
WOT from a roll from the inside:
http://www.youtube.com/watch?v=6PJXwoljdWs
Revving and idle from the outside: http://www.youtube.com/watch?v=iTOBpr41K64
I have a video with cruising from inside the car but for some reason there's a lot of noise in the video. It'spretty quiet just cruising at 65-70.
WOT from outside:
ORIGINAL: Nixtang
Did you have any error codes after the h-pipe install, or did you just get an updated tune?
Nick
Nick
Cool, thanks for the info!
Did you notice any type of decrease in power? I realize that Brenspeed claims a 8 hp increase, but most likely, the increase is on the top end. I've been thinking about purchasing this h-pipe, but don't want to if it loses power down low.
Where'd you take those videos? I think I know where that's at...
Nick
Nick
