Sponsored by:
Sponsored by:
Lug Nuts Anyone
Old 06-07-2019, 04:21 PM
Boss302vla
Boss302vla's Avatar
Default Lug Nuts Anyone
I am looking for some solid steel or aluminum lug nuts that fit a 2005 mustang. It is Roush Stage 3 with SVT rims. The current lug nuts seem to be factory 1.5" acorn style chrome lug nuts that have chrome over the top of the lug nut. Over the years the outer layer has twisted due to the use of impact wrenches by others. I would like to find a good quality solid lug nut in black or gray type color. I have not had much luck - other than some racing style which won't look good on the car. I have attached some pictures. Thanks in advance.
Boss302vla is offline
Old 06-07-2019, 05:26 PM
Moderator
JimC's Avatar
I just got some from Discount Tire, and they aren't the two piece like the stock ones (which twist and swell as you have found).
I have seen Gorilla lug nuts at O'Reilly's as well.
JimC is offline
Old 06-07-2019, 06:46 PM
Siber Express
Siber Express's Avatar
Pick your Poison Gorilla Lug nuts
Siber Express is offline
Old 06-09-2019, 08:19 AM
Boss302vla
Boss302vla's Avatar
I will give Discount Tire a try. Thanks.
Old 06-10-2019, 10:32 AM
GT Nate
GT Nate's Avatar
if those are aftermarket wheels, you may need tuner lug nuts....
GT Nate is offline
Old 06-10-2019, 10:33 AM
GT Nate
GT Nate's Avatar
I stripped mine on my rear passenger side. Goodyear put on new ones...problem solved.... way to easy to strip them!
GT Nate is offline
Kidcruz
Convertible Tech
04-04-2018 08:38 PM
brent4
10-16-2011 12:06 PM
1999 GT
12
02-01-2009 07:28 AM
MS3Stang
Wheels & Tires
09-20-2007 01:57 PM
olesch
12-27-2005 04:24 PM
Quick Reply: Lug Nuts Anyone
