Steeda Ultralight lowering springs install (w/pics)
#31
RE: Steeda Ultralight lowering springs install (w/pics)
Another big THANK YOU to TacoBill for a great write up. Used it to help install myEibach Pro kit this weekend. Everything went just as you wrote it.
Thanks again!!!
Thanks again!!!
#32
Taco Bill,
Thanks for the great write-up. I installed my rear springs this morning using your instructions. Very easy install and very helpful with your step by step color photos.
Bret
Bret
#35
Bill, You is da man fo sho! There is no one else that is as thorough as you when it comes to thesetutorials that you do. I am absolutely convinced that you never drive your car. Based on all of these pictures you post, that car belongs in a museum! The underside is cleaner than most operating rooms! Great job once again!
#36
Glad you guys are still enjoying and using this write-up.
And you're right jeran, I need to drive mine in the rain and get down and dirty with it. [8D]
(or not! LOL!!!)
(or not! LOL!!!)
#37
Hey TacoBill,
I glad to hear the a new adjustable Panhard bar is not really needed. There are so many writeups that say you should get one, but they never really come out and say when - how much lower when one is required. I am planning on putting the below when my '08 GT Vert comes in.
Steeda Ultralite Springs
Steeda Rear Swaybar w/ End Links (The description says that the swaybar needs endlinks for a Vert)
Steeda Adjustable Front Swaybar
Steeda Pro-Action shocks
#38
ORIGINAL: garbledwords
The requirement for the adj. bar is also more pronounced if you're running wide tires out back. Running the stock 235's, it's hard to see if the rear axle is shifted 1/4" one way or the other. But, running 295's, it's alot more apparent.
Luckily for me, it seems that my axle was off center from the factory. After lowering it, it happened to be dead center.
#40
Thanks for the feedback. I understand that there is no definitive answer to that. But you are the first that I have seen to say that that combination was not needed - at least on your car, and you measured it. What I was going to do is to but the stuff one and see how much out of adjustment I would have before I bought one.
But it is still mistifying why almost all of the suspension packages do not have one.
