Sponsored by:
Sponsored by:
Just installed aluminum driveshaft!
Old 05-01-2007, 12:20 AM
jerjan
jerjan's Avatar
Default Just installed aluminum driveshaft!
I just installed an aluminum one peice driveshaft on my GT. What a difference! My Gt is the first manual trans car I have owned in years. When I first got it, I thought I had forgot how to drive a stick shift asit was really jerky when shifting. What I did not realize is that the problem was the clunky two peice driveshaft. The car is so much smoother to drive and is noticeably quicker. This has got to be one of the best mods ever and I recommend it highly. Any one else gone to a one peice and really like it?
jerjan is offline
Old 05-01-2007, 12:33 AM
Bluestar
Bluestar's Avatar
Default RE: Just installed aluminum driveshaft!
Sounds nice, which one did you get??
Bluestar is offline
Old 05-01-2007, 12:37 AM
jerjan
jerjan's Avatar
Coast driveline $572 from stangsuspension.com. At 17lbs it is 50% lighter than the stock boat anchor.
jerjan is offline
Old 05-01-2007, 12:43 AM
Bluestar
Bluestar's Avatar
Bluestar is offline
Old 05-01-2007, 01:53 AM
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
1+
mygt500 is offline
Old 05-01-2007, 07:41 AM
ilmor
ilmor's Avatar
I think that's a great idea.
ilmor is offline
Old 05-01-2007, 11:12 AM
Timmay!!!
Timmay!!!'s Avatar
Any vibration issues at higher speeds, or any speeds for that matter? How about clearance, did you have to relocate the e-brake bracket?
Timmay!!! is offline
Old 05-01-2007, 11:39 AM
moosestang
moosestang's Avatar
I felt the same way and almost used the same words as you to describe the difference. Very smooth now and it feels like your foot is directly connected to the engine.
moosestang is offline
Old 05-01-2007, 11:40 AM
jerjan
jerjan's Avatar
Absolutely no vibration, The stock driveshaft actually had a slight vibration and a whole lot of slop. I did not have to relocate anything. It has adequate clearance from the e-brake cable. Very easy installation, I did it on my garage floor with jack stands, it took a little under 2 hours from start to finish.
jerjan is offline
Old 05-01-2007, 11:41 AM
moosestang
moosestang's Avatar
More than 50% lighter. I weighed the stock shaft and it weighed 41 lbs on my bathroom scale.
ORIGINAL: jerjan
Quick Reply: Just installed aluminum driveshaft!
