Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2014 Mustangs
Sign in using an external account
Register Forgot Password?
Search
2005 - 2014 Mustangs Discussions on the latest S197 model Mustangs from Ford.
Welcome to Mustang Forums!
Welcome to Mustang Forums.
CMCV Delete Plate install (with pics)
Old 04-13-2009, 05:53 PM   #61
james432
james432's Avatar
So junk the motor and the stock plates lol
james432 is offline   Reply With Quote
Old 04-13-2009, 06:31 PM   #62
snkebitel
snkebitel's Avatar
Vehicle: 06 Ford mustang GT
great thread
__________________
06 gt convertible: frpp stinger,o/r h, c&l street cold air, mgw shifter, Xcal3, steeda udp; delete plates; bbr tune
02 gixxer 1000-------stolen
87 grand national--fast as h@@
snkebitel is offline   Reply With Quote
Old 04-27-2009, 02:15 PM   #63
vasman
vasman's Avatar
Vehicle: 2007, GT CS, Convertible
Bill you are the Man! Thanks a lot for the write up. I have 4.10's on so did not notice the low end torque loss. I do feel the car sounds better even more throaty with my setup, hi rpm feels more aggressive, and my butt dyno feels some small increase in power.
I can not wait until you do a write up for LT headers and Comp cams.
__________________
2007 GT/CS vert, Techco 3L TS@10 PSI
Kooks LTs H-pipe, Borlas
3.55 gears, Dynotech 3.5" Alum. Drive shaft
Steeda Superlights, Tokico D Specs, BMR-UCA/LCA-Relo Braket- Adj.Panhard bar
Brembo's, CHE K Brace/torque limiters, Prothane MMs, Ford Racing STB
MGW shifter, Spec Stage 2+ Clutch, Dual GT500 Fuel pump, 62mm BBK TB 255/45/18, Flaken RT615K 295/40/18 , Agent 47 Mirrors
vasman is offline   Reply With Quote
Old 03-20-2010, 11:39 PM   #64
Riptide
Riptide's Avatar
Vehicle: 2014 GT
What are the factory torque specs on the intake bolts? Steeda's documentation doesn't say and neither does the writeup.
__________________
WILL WORK FOR MUSTAKE
Riptide is offline   Reply With Quote
Old 03-21-2010, 12:28 AM   #65
stealth_GT
stealth_GT's Avatar
Vehicle: 2013 Dodge Charger RT AWD
Quote:
Tighten in the sequence to 10 Nm (89 lb-in).
__________________
13.3@102, stalled/tuned, 4685lbs.
stealth_GT is offline   Reply With Quote
Old 03-24-2010, 02:26 AM   #66
RetroGT2006
RetroGT2006's Avatar
Vehicle: 2006 Ford Mustang GT
Send a message via AIM to RetroGT2006
Thanks Bill! I used this thread today when i did my delete plates myself in the garage. Worked great, now to use the one you did for the UDP's on tomorrows install =0).
__________________
Stangforce.com
2006 Windveil Blue Mustang GT
Slightly Modded =)
RetroGT2006 is offline   Reply With Quote
Old 03-24-2010, 06:15 AM   #67
MADSCOTSMAN
MADSCOTSMAN's Avatar
Vehicle: 2013 Mustang GT
Not really sure how much has changed part-wise since 1994-95, or how the differences between a 94 GT 5.0 and an 05-10 4.6 add up, but I had UDP's installed on my 94 GT back in the day (along with many other mods ). One thing I noticed (and hated), was when the car sat idle, the A/C was almost non-existant. I used to go to the street machine nationals (while in college, I lived in Carbondale, IL, they were held in Marion, IL, I believe). It was a huge car show/cruise with thousands of cars and people (car equivalent of today's Sturgis). Needless to say the cruising involved sitting idle in your car in 90-100 degree temperatures in long lines of cars, and the need to have the A/C on from time to time was required to prevent a heat stroke. With the UDP's on, the A/C barely blew at all when idling (you had to hold the pedal down a little to keep the RPM's up to get any cold air to blow at all, and it still wasn't enough). Just my .02, but if you like A/C in the summer, prepare to do some serious sweating, if you live somewhere hot, while sitting in traffic. Unless something is drastically different between how these function with the old school 5.0 and our newer 4.6.
MADSCOTSMAN is offline   Reply With Quote
Old 03-24-2010, 09:21 AM   #68
RetroGT2006
Quote:
Man that blows, but they must be drastically different. I have been in many many cars with them and the a/c was exactly the same lol. Nothing was changed, or anything i could feel. Still pushed out plenty of cold air.
__________________
Stangforce.com
Slightly Modded =)
Old 03-24-2010, 10:06 AM   #69
Riptide
Riptide's Avatar
Vehicle: 2014 GT
Same here. My friend's car still has decent AC with the pulleys on there. So does mine. Pulleys took me a long time to install, most of the day, mainly because of inexperience but also somewhat due to me taking my sweet time along the way. Delete plates probably gonna be the same.
I was amazed at the torque specs for the intake. 7.4 foot lbs. torque for those bolts. Wow that's like nothing!
__________________
Old 03-21-2011, 11:48 PM   #70
whoapony
Just wanted to say thanks! I used your write up and all went very smoothly!
whoapony is offline   Reply With Quote
Old 11-25-2011, 08:44 PM   #71
Caine197
Caine197's Avatar
Vehicle: 2005 Ford Mustang GT
http://www.facebook.com/colteparker colteparker Caine197
Great write up, just used this to install CMCV Deletes as well as UDP's.
Caine197 is offline   Reply With Quote
Old 01-05-2012, 08:58 AM   #72
hailtyr69
Vehicle: 06 ford mustang gt
Default cmcv delete plates
ok guys. new to the forums but been a builder for a while. I recently went with the cmcv delete plates for my 06 gt and have a problem. I tried to upload the program with the delete option that I have and the car wouldn't even run. went back to the program without the delete option and it would run pretty good but goes into limp mode if i really get on the throttle hard. also is throwing a code (p061) that i have never heard of. Please help me. I feel like i'm chasing my tail here.
hailtyr69 is offline   Reply With Quote
Old 01-05-2012, 10:57 AM   #73
BigDinTexas
BigDinTexas's Avatar
Vehicle: 2012 Kona Blue GT Premium
Quote:
Who wrote the tune for the delete plates? AM/BAMA, Brenspeed, etc..
Don
__________________
-“If you can't be a good example, then you'll just have to be a horrible warning.” ― Catherine Aird
BigDinTexas is offline   Reply With Quote
Old 01-05-2012, 08:31 PM   #74
hailtyr69
Didn't have a program written for it. The sct programmer I have has the cmcv delete in it. Thinking about just getting it dyno tuned
Old 01-11-2012, 08:33 AM   #75
hailtyr69
Had a custom tune written by Brenspeed instead of a dyno tune. Fixed the problem and can def feel a difference in the top end with the cmcv deletes. Car has a deeper tone that I love. Now time for some long tubes.
Old 09-16-2013, 01:01 PM   #76
mjunda
Where are all the pictures? Please upgrade you photo bucket account so they are viewable.
mjunda is offline   Reply With Quote
MustangForums
Ford Mustang
Paid Advertisement
account, charge, cmcv, delete, install, installation, installing, money, motion, motor, mustang, plate, plates, remove, steeda, worth
Similar Threads
Charge motion delete plates Midnight Express 2005 - 2014 Mustangs 18 04-29-2009 02:37 PM
What Trottle Body to purchase? flg2010 2005 - 2014 Mustangs 36 04-06-2009 04:16 PM
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Emails Backup
