Last edit by: IB Advertising
Browse all: Ford Mustang Exterior Guides
- Ford Mustang V6 and Mustang GT 2005-2014: How to Install Front Lip
Step by step instructions for do-it-yourself repairs.
How To: Amp Install (w/ Pics! 56k warning)
RE: How To: Amp Install (w/ Pics! 56k warning)
ORIGINAL: lundis
im going to disagree with your methods, but i may be talking out of my *** since i do not yet owna mustang (waiting for 08)
i NEVER install power wires through the wheel well. ive seen too many wires corrode and cause shorts (and therefore, fires) from that. i always run it through the firewall, through the main grommet. if there is no grommet (im not sure on a mustang...but most newer cars have one) then i drill one. this is a difficult method, and best left to pros, but the RIGHT way to do it.
ORIGINAL: Joe Time
So How does the Shaker 500 System sound now with the Amp Installed? Considerably Better???
ORIGINAL: wthalliii
Nice writeup. What speakers did you use and how did you mount them? Somebody already asked, but how do they sound?
As for the speakers and how did I mount them, I'm going to assume you mean my subs as I did not replace the factory speakers. I have 2 12w0 JL subs in a box. Right now they are just sitting in the trunk as I'm trying to devise a way to hold them down how I want (upside down and leaning against the seat incline).
ORIGINAL: lundis
Nice write up BTW. If I had more time and energy after working the 60Hours + a week I would have done it myself, I used to love doing this as a kid. Thank god for sabbaticals, mine coming up this year.....
ORIGINAL: 07SCGT
ORIGINAL: 157db
Scotchlocks? Shame on you. And that ground connection
leaves something to be desired. A wood screw into wood?
For the record, I also used a multimeter to verify that the tab was properly grounded.
It's easy to bash but explain why what I did was wrong. If you have a legit point, I'd love to improve my knowledge and help out the next person.
Excellent write-up my young Apprentice! [8D]
It wasvery well written and all the stepsin logical order. What I try to accomplish in my write-ups is for anyone to view the steps and perform the mod or install. No matter how simple or obvious a step is, I still spell it out, just like what you did on disconnecting the battery.
Again, good job!
Again, good job!
And just how did you use that multimeter to check the ground connection?
With the Ohms setting? Or did you do a voltage drop test from the amp
ground input to the negative post on the battery? I need more info on this
correct way you did things. And using scotchlocks? I am not into bashing.
I recently installed fogs and got it all hooked up OEM. I paid premium
for a "custom harness". It was full of scotchlocks. What a waste of $80.
You can bet there were no scotchlocks when I was done. And I have
the logic like I want it. OEM switch and all. Invest in a good soldering iron
and some heatshrink.
Tape is a no-no in my book.
I can see where youre coming from on the scotch locks... I dont think it will be a problem on the inside of the car... Ive used them before without any issues. Its when people use them to do things like wiring trailers that they almost always end in a catestrophic failure. Soldering is best, but a good crimped on butt spice usually works pretty well too.
ORIGINAL: 157db
