Sponsored by:
Sponsored by:
Old 10-22-2015, 03:52 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Exterior Guides
Print Wikipost
How To: Amp Install (w/ Pics! 56k warning)
Old 08-04-2007, 11:28 PM
  #41
Aziraphale
Aziraphale's Avatar
Default RE: How To: Amp Install (w/ Pics! 56k warning)
ORIGINAL: Bmr4life
Awesome write up. Luckily my amp has built in speaker line inputs so I didn't have to use the RCA adapter. I'm still trying to figure out how my mount my sub box.
Thanks. I'm still havn't mounted mine permantely yet. It is currently resting upside down up on the incline so I still have a usable trunk. If I get on it too hard, it does shift on me a bit though.
Aziraphale is offline
Old 08-05-2007, 10:16 AM
  #42
Bmr4life
Bmr4life's Avatar
Problem with my box is it's only around 9 inches deep so it can topple over pretty easily. Here are some pics of what I have finished so far.
I plan on building a box for the passenger side also. I did it this way because I still want to be able to utilize the fold down rear seats.
Bmr4life is offline
Old 08-05-2007, 02:20 PM
  #43
Shard Phoenix
Shard Phoenix's Avatar
This is exactly how I did mine, and I never had any issues with it.
That being said, Great post!
Shard Phoenix is offline
Old 09-16-2007, 10:06 PM
  #44
luckydawg003
luckydawg003's Avatar
Can you run 2 gauge power wire thru the grommet in the firewall?
luckydawg003 is offline
Old 09-16-2007, 10:12 PM
  #45
8URGTO
8URGTO's Avatar
kick bu** artical man!!!! I am getting ready to do the same ..... thanks!!!!
8URGTO is offline
Old 09-16-2007, 10:33 PM
  #46
nkx1
nkx1's Avatar
Awesome writeup Aziraphale, thanks! I am planning on transferring the systemfrom my old car to the stang, and your write up will take out a lot of the guess work for me! I have the Ford dealer repair manual DVD that I was initially planning on using, but that DVD is really annoying to use, and I like all the pictures you provided!
I was only going to suggest one minor alteration to your method:
Insted of cutting the "nipple" on the grommet, I normally just drill/poke a hole in it, and then push the wire through. That way, it's pretty much air/water tight without even having to use tape or other method of sealant. Either way works, I suppose.
nkx1 is offline
Old 09-16-2007, 10:36 PM
  #47
nkx1
nkx1's Avatar
Bmr4life, does that upside down amp mount work well for you?
In all the amp manuals I've ever read, it is always suggested not to mount the amp upside down because it can't adequately cool itself (you know, the whole hot air rising thing).
nkx1 is offline
Old 09-17-2007, 08:26 AM
  #48
TPony
TPony's Avatar
A fine tutorial!
TPony is offline
Old 09-17-2007, 08:43 AM
  #49
Aziraphale
Aziraphale's Avatar
ORIGINAL: luckydawg003
Yup, shouldn't be a problem. The gromet is pretty flexible rubber so you should be able to cram a 2 gauge power through there.
ORIGINAL: 8URGTO
Thanks, it is worth it if it helps someone else!
ORIGINAL: nkx1
That's a good idea. Usually I do that too but the nipple was just there and looked like the correct size so I just sliced it off. If I were doing it again, I'd probably poke it through.
ORIGINAL: nkx1
I gotta agree with the amp manuals here and say that it isn't good to mount them upside down like that. The heat will just radiate back up into the amp rather than disappating like it is supposed to. While the amp may work fine for now, it may have a shortened life span or something.
Old 09-30-2007, 10:12 PM
  #50
luckydawg003
Nevermind. I just didn't look close enough to see that it still goes thru the fender. So the wire should be ran thru the grommet then into the fender then thru another grommet to the engine battery right?
Quick Reply: How To: Amp Install (w/ Pics! 56k warning)
