How To: Amp Install (w/ Pics! 56k warning) - Page 8 - MustangForums.com
Sponsored by:
Sponsored by:
Old 10-22-2015, 03:52 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Exterior Guides
Print Wikipost
Old 12-10-2013, 08:10 PM   #71
runstang22
runstang22's Avatar
as for the comment above, the shaker 1000 cannot replace the 500 directly. You must replace the head unit because their is an extra connector output from the head unit on the 1000 that sends signal to the Sub. My question is this: I didn't really understand when you were talking about the amp always being on - how connect it so that the amp is not constantly draining the battery even when the car is off? Is there a throwover relay you installed or a setting on your amp?
runstang22 is offline   Reply With Quote
Old 05-04-2014, 04:11 PM   #72
CreekMustang
CreekMustang's Avatar
Default Electrical Connector in Trunk for Shaker 1000?
Great post BTW!
We're installing an amp and sub into a 2007 V6 Mustang with a Shaker 500. Does anyone know what this pigtail connector is for in the trunk? I'm wondering if it is for an upgrade to Shaker 1000 and could be used to tap into the speaker signal.
 How To: Amp Install (w/ Pics! 56k warning)-photo-1.jpg    How To: Amp Install (w/ Pics! 56k warning)-photo-2.jpg
CreekMustang is offline   Reply With Quote
Old 08-29-2015, 04:38 PM   #73
simplemansfaith@gmail.com
Default Wow
First of all...Wow!
Very nice instructions. Pictures help even better. Very...very nice work my friend.
Thanks for making it easy for all Mustang owners.
Chive on!
Art
simplemansfaith@gmail.com is offline   Reply With Quote
Old 09-03-2015, 10:32 PM   #74
cbird1177711
Default dash kit?
When installing the head unit, do you use the stock head unit's mounts and screw them onto the new receiver or the mounts included in the kit? It has the front piece like in my first pic, but do I screw on the plastic piece to the side of the head unit as well or use the stock one? Or does anyone know of a thread with pics or instructions of how to connect the dash kit to the head unit? Thanks!
cbird1177711 is offline   Reply With Quote
BMR Suspension, DSS, Barton and Viking Performance all going in today!! Boostaddict 2.3L Eco-Boost Tech 2 11-24-2015 06:11 AM
Outer shock tower braces guitarman376 Classic Mustangs (Tech) 6 10-11-2015 01:47 AM
Noob needs help! 86 mustang svo motor swapped to 71 5_speed carb 302 v8 jaiidutch Motor Swap Section 2 09-14-2015 10:29 AM
First Mustang 99' 3 differnt body kits installed TimeLord101 New Member Area 3 09-04-2015 09:27 AM
Help! Metra 70-5521 AMP Harness Install cbird1177711 2005-2014 Mustangs 2 09-03-2015 08:43 PM
1000, 1000w, 500, amplifier, amps, california, cord, install, installation, instruction, mustang, place, power, radio, remove, shaker, stock, work
