Where to get a Limited Slip?
I'm having a hard time locating a limited slip for my car, also how good is it of an idea to get one?
06 v6 Pony for the record. Don't they have these as take-off parts anyway?
How will it affect the car?
RE: Where to get a Limited Slip?
http://www.newtakeoff.com/index.asp?...mp;ProdID=7855
Thanks, so this is the limited slip I'm guessing, how does this compare to the aftermarket ones?
Question is, do you want to change the entire rearend assembly to a GT takeoff 8.8"? Or do you want to add a limited-slip diff to your existing 7.5" rearend? Putting a limited-slip in your existing housing(parts, labor and ring/gear change) would probably be around a grand. Changing to a takeoff 8.8"(if you do the change over yourself) would maybe save a few bucks and add strength at the same time.
You'll notice the difference after the change the first time you race at the track(or go around a corner while still on the throttle).
Get the 8.8" take-off, no brainer, good luck!
I can see your point, but how much weight will the 8.8 takeoff add? I'm rather fond of how light the v6 is. I was hoping for a part that's under $500 that I could put on myself, and was unaware the axels themselves were different.
If it's a significant investment I don't see how it's worth the price, over say a locking torque converter. ($700)
Considering I'm getting a supercharger this New Year, though it may be a good investment, the v6 rear axel is weak and now that I'm aware of that.
Thoughts? Would you take the overpriced 8.8 rear end over a Locking Torque Converter?
ORIGINAL: Legion5
Ok I'm going to assume that you don't need to set preload on a 8.8 takeoff. How easy is one to install? Or would it be better to have a shop do it?
