Sponsored by:
Sponsored by:
Coolant temp sensor problem?????
Old 09-10-2014, 05:13 PM
DarkGaV6
DarkGaV6's Avatar
Default Coolant temp sensor problem?????
Ok... Once could of been a bad sensor, twice maybe the wrong sensor, but three times this summer. It has to be something else.. I have had to replaced my coolant temp sensor three times this summer. What gives, I have begun to think the sensor failing is a symptom not the problem. The only thing I can think of is maybe there is a issue in the AC system that's causing it to fail. ANY input or things to check will be greatly appreciated. I will be replacing it again tomorrow.
DarkGaV6 is offline
Old 09-10-2014, 05:20 PM
Simon1
Simon1's Avatar
Is it the cylinder head temp sensor? How do you know it's failing?
Simon1 is offline
Old 09-10-2014, 07:10 PM
DarkGaV6
DarkGaV6's Avatar
its the sensor that plugs into the thermostat housing, when it fails the cooling fan doesn't work.
DarkGaV6 is offline
Old 09-10-2014, 08:02 PM
Simon1
Simon1's Avatar
Awe. Sorry I haven't dealt with that. If it keeps failing, I would look at the wiring going to it.
Simon1 is offline
Old 09-11-2014, 06:10 AM
DarkGaV6
DarkGaV6's Avatar
I've thought of that. I'm not getting any error codes and my diablo programmer isn't pulling any problems either.
DarkGaV6 is offline
Old 09-11-2014, 09:37 AM
2005Redfire6
2005Redfire6's Avatar
Could be your fan relay.
2005Redfire6 is offline
Old 09-11-2014, 04:08 PM
DarkGaV6
DarkGaV6's Avatar
I thought of that and replaced the low and high speed relays with the on for the rear defroster( its the same type) no luck.
DarkGaV6 is offline
Old 09-12-2014, 09:43 AM
DarkGaV6
DarkGaV6's Avatar
I took it to the shop this morning, their best guess is a bad ground wire. I will be running a new one today.
DarkGaV6 is offline
Old 10-02-2014, 07:25 PM
stangster98
stangster98's Avatar
Default coolant temp sensor
I have a quick one if someone could help me with it. Are the two coolant temp sensors the same on a 98 gt? I bought one from oreillys and want to make sure it will go on the spot where the gauge one goes just in case they sold me one for the computer. Thx
stangster98 is offline
Old 10-02-2014, 08:07 PM
Moderator
JimC's Avatar
Probably will get a better response posting in the correct section. You are in the S197 (2005-10) section.
JimC is offline
Jb145700
08-21-2022 06:37 AM
Granatelli Sales
01-20-2020 12:34 AM
TfcCDR
09-14-2015 12:08 PM
MusicCity615
09-12-2015 07:05 AM
96stang3.8
09-10-2015 06:42 AM
Quick Reply: Coolant temp sensor problem?????
