Stripes bunching vinyl under hood scoop?
#21
RE: Stripes bunching vinyl under hood scoop?
Yeah, I have the bunching with my Roush scoop as well. And, I have had the scoop off, removed the 3M tape and replaced with weatherstripping, to no avail. If the weatherstripping is too thick, then the scoop rides up and looks like crap. If not thick enough, bunching........
Mike
Mike
#24
ORIGINAL: bplemmons
Can someone take some close up pictures where of the vinal bunching up so I can see what it's going to look like?
Bill
Bill
#26
Thanks for the pics wingman - I had read about this but never seen it - looks bad. Just wondering - does this happen to everyone? If not, it must have something to do with the particular scoops. Please keep this thread going as I was seriuosly considering getting a Roush scoop and stripes but will hold off if this happens to most people or if a cause/effect isn't identified.
ORIGINAL: wingman75
Here is what mine looked like.
ORIGINAL: bplemmons
Bill
Bill
#27
ORIGINAL: rogan01
I have talked to Rob about this as I said in the first post and if you guys are not letting him know he has no incentive to correct the situation. Please let him know... send emails or call him. Thanks!
#29
ORIGINAL: wingman75
I agree no one can cut them without cutting into the paint/clearcoat. What I have proposed to Rob is to design the pieces for the hoods with a cutout to match the hood scoops shape just as he has designed around the license plate opening and the fake gas cap in the rear. Then the scoop would not need to be removed to install the stripes and it would not rest atop the vinyl. I just hope he realizes that this is a problem for a lot of guys and it makes sense to address it.
ORIGINAL: fairlane292
The ony thing is, cutting around the scoop will leave cuts in the clearcoat. You won't see them with the stripes on but when you remove the vinyl you will see this; I don't care how experienced the vinyl graphics guy is. I helped out in a family run shop for over a year; how doyou exacto cut down through the vinyl and not touch the cc even lightly with the knife ? Can't be done at least not with near 100% success. Saw many attempts to do this and while I was very adept with the knife, it was virtually impossible for me as well, no matter how slow, careful and well lit the surface was. I'm thinking the best approach is a thin to medium layer of clear silicone caulk on the scoop, let dry, then apply a fresh thin layer of same and bolt down but only so the new film of silicone meets the vinyl . After it dries give the nuts another1/2 turn. Use locking nuts! The silicone should flex and not grab the vinyl causing it to bunch up. No guarantee this will solve the problem; scoops aren't meant to be put down on vinyl.
#30
I'll tell ya Wingman, I just don't know if Rob or anyone can "...design the pieces for the hoods with a cutout to match the hood scoops shape" with the precision that is needed to get the alignment right on with barely no spacing, evenly around the scoop; ...maybe if the scoop location is slightly adjustable. Are the bolts in the scoop a tight fit in the holes in the hood? In theory if the scoop can't move it will not bunch the vinyl. I might consider this; bolts that snug fit to hood holes; mark/outline the leading front corners (and any place where bunching occurs), get so where you can pull the vinyl up inside of these areas where it is not visible. (pick at vinyl, w/o cutting through, raise up an area and then can cut where the outline you have made is, w/o touching the clear). If the areas that bunch up are removed and the bolts fit snug I really don't see the problem reoccurring; with a hairdryer, some soapy soultion you may be able to straighten out and save what was bunched up. Good luck man.
If you are suggesting marking the scoop outline then lifting the vinyl a little then cutting, I think the vinyl will stretch out of shape and end up being a wavy looking edge. If Rob doesn't want to attempt a fix I'm sure some other stripe provider will. This could turn into a bigger issue as more people get scoops and stripes and they develope this problem.
Thanks for the input. You always have well thought out advice.
