Sponsored by:
Sponsored by:
Is my dealer lying to me?
Old 07-30-2007, 09:54 PM
gregsanch
gregsanch's Avatar
Default Is my dealer lying to me?
I've got an 05 Mustang, v6 manual, and it's been having difficulty shifting lately. Sometimes you really have to struggle to get it into 2nd or 3rd gear.
Took it into the dealer to check it out, and they said it's normal because it's a non-synchro transmission.
Is this BS?
gregsanch is offline
Old 07-30-2007, 10:12 PM
LegallyTorchRED
LegallyTorchRED's Avatar
Default RE: Is my dealer lying to me?
Change your fluids, and LIFT some weights.
LegallyTorchRED is offline
Old 07-30-2007, 10:16 PM
owero01
owero01's Avatar
It shouldn't be hard to shift. Go to another dealer if possible.
owero01 is offline
Old 07-30-2007, 10:18 PM
PROMETHEUS PRIME
PROMETHEUS PRIME's Avatar
Hows the clutch feel and how do you drive it?
PROMETHEUS PRIME is offline
Old 07-30-2007, 10:21 PM
Timmay!!!
Timmay!!!'s Avatar
I thought all manualtrannys since like the 70s have had syncros. Otherwise you would have to match road speed to revs everytime you wanted to shift.
Timmay!!! is offline
Old 07-30-2007, 10:23 PM
dirtydeedsinc
dirtydeedsinc's Avatar
Dealership lie? You must be kidding. They never do that.
dirtydeedsinc is offline
Old 07-30-2007, 10:29 PM
05gtdriver
05gtdriver's Avatar
ORIGINAL: gregsanch
Is this BS?
If that were the case, do you know how to "double-clutch"? Your dealer is retarded, only reverse is non-synchro(which is why you must be at a full stop in order to engage reverse). My dad use to have an old Chevy truck(40's model) and you'd have to double clutch it, meaning youstep onthe clutch to get trans out of gear(and into neutral), let clutch out, then step on the clutch again to engage the next gear.
In the movie "Bullitt", Steve McQueen is double-clutching the Mustang as he chases the bad guys up that last hill before the expolsion scene.(for sound effect reasons, because synchro type trans have been around since the 50's in mass produced American cars).
Do your difficulties with shifting occur after start up or all the time? Cold tranny fluid would cause some notchiness, but not to the point where you can't shift smoothly. Are you new to driving stick-shift?
05gtdriver is offline
Old 07-30-2007, 10:33 PM
PROMETHEUS PRIME
They are unfortunatly full of it.
The T5OD 5-speed transmission features:
[*]fifth speed gear functions as an overdrive gear.[*]forward gears are synchronized and helical cut.[*]shift interlock system prevents the engagement of more than one gear.[*]has an aluminum main case, extension housing and bellhousing.[*]has an input shaft, output shaft and countershaft.[*]reverse idler gear is used to produce a reverse rotation of the output shaft.[/ul]
Old 07-30-2007, 11:01 PM
Orion_240
Orion_240's Avatar
and if you have any difficulty in getting it going they'll probably advise you to put your feet through the floorboards and start running, like Fred Flintstone!
Orion_240 is offline
Old 07-30-2007, 11:24 PM
AmericanMuscle4.6GT
AmericanMuscle4.6GT's Avatar
non-synchro transmission? are you kidding me?
AmericanMuscle4.6GT is offline
Quick Reply: Is my dealer lying to me?
