Speaker Pop
Speaker Pop
I have an Eclipse AVN-30D installed and when I start the car I get the pop noise. I have read that a reisistor or the 12v to 5v adapter fixes it. Where dies it install to does anyone have pictures of this? If so can you explain on what I need to do and make it as stupid simple as possible! lol Thanks for your help
RE: Speaker Pop
Here's one link that will help. Not a Skipper 500, but same installation of the resistor...Or, just go up top and check out Taco Bill's hot links of his install.....
Mike
http://www.dennisjudd.com/archives/000947.html
Mike
RE: Speaker Pop
It is due to exactly what was said in the link posted above. Voltage difference between what your aftermarket head unit puts out for an amp on signal, and what the factory head unit put out for the same signal. Just do what is instructed in that link and it will go away. Pretty old issue that was solved quite some time ago.
On a side note.. damn shame that guy put that much time and energy in to that write up, and called a voltage regulator a transistor...
RE: Speaker Pop
ORIGINAL: hawgman
http://en.wikipedia.org/wiki/Transistor
RE: Speaker Pop
That would be like saying that anything that contains a transistor IS a transistor..
Here, since you are wiki dependant.
http://en.wikipedia.org/wiki/Voltage_regulator
RE: Speaker Pop
ORIGINAL: hawgman
breaking
10-02-2015 01:27 PM
