DTE FLI DATA ERR (Help!)
I was cruising with a bunch of buddies after a group DYNO session and a GTO who thought he was a bad-as* came up along side me and we went for it and instead of getting another in a looong list of kills, my motor died and I coasted to the side of the 55 and my battery was stone cold DEAD...After we put some jumper cables on it, I ran the diagnostic and it came up with DTE FLI DATA ERR and the engine just will not pump a drop of fuel (we pulled the hose off in the engine compartment). There does not appear to be any power going to the pumps (I checked with a volt meter). I had it flat bedded back to my house and am looking for anyone who has any idea's into why this code is coming up and what is causing it? I already pulled the NEG off the battery and I'm getting the same message!
Help!
GT500OC
Help!
GT500OC
RE: DTE FLI DATA ERR (Help!)
i'm slippin...
first thing is to check the fuel pump
shutoff switch
in the '06, it's near the drivers left leg area
if the shutoff is ok, then check relay #21 in the engine compartment
fuse box
shutoff switch
fuse box
I did have an overheat that sprayed the engine compartment up at Willow Springs a few weeks ago (shocking when it was 115 degrees), do you think that that might have caused a short in the box? NO IPOD...
GT500OC
GT500OC
