Cold Air Intake w/ no Tune...is it even worth it?
I keep reading forums on the BBK, JLT & C&L Intakes requiring a Tune to really feel the performance boost but almost everyone has mentioned it voiding the warranty. Meaning Ford can see that the Computer has been reflashed even if returned to stock!! My dilemma is I have an extended warranty that I dont want to waist
(75000)miles on a New 06 GT Auto.
Is it even worth me spending the $200 getting a K&N that does not require a tune? It would probably just end up looking better than really making the car perform better right??
RE: Cold Air Intake w/ no Tune...is it even worth it?
But if you get a Jlt/C&l with a tune you can always put the stock air box on and flash back to stock,if going to the dealership.
Never heard of the dealership finding out someone had a tune if everything is back to stock !
30mins later !!!!!!!!!
Well...now I've heard..lol. Watching the speed channel and they was talking about dealerships reading "foot prints"on the computer
and can void your warranty!
i have the mrt and i think it was worth it. i felta difference with it in throttle response and some mid range power. if u can afford it right off the bat go with a intake/tune combo like ti or c and l. i dont regret getting mine tho.
I have the BBK CAI (no tune requied) and I ran it for a while with out a tune. It helps it run stronger but it causes the car to run lean. I opted to go to Brenspeed and get the tune they have for the BBK. It brings air/fuel ratio's back in line and it gives good low end torque. I would go with a CAI that requires a tune and buy it as a package. If a dealership questions why the history has been cleared all you have to tell them is that you removed the battery cable to see if the engine light(code) would clear. I have heard that is sufficient. I have not heard about the footprint thing. Hard to prove if everything is returned to stock. Could have been a factory program issue! Have to prove it.
If you are worried about your warranty keep your car stock untill 70,000 miles. There is no other way to put it.
If you put a CAI on your car without a tune you are pretty much guaranteeing that you are going to need to use that warranty considering you will F*ck your engine up.
Any just so you know, if you get a cai and a tune the only warranty that is void is your engine. If your steering wheel falls off they will fix it, ect...
I havent heard of an engine blowing from a cai and a tune, and that is the only thing being voided.
ORIGINAL: ohsixgt1217
http://www.cnlperformance.com/notune.html
I installed an Airaid CAT on my 2006 gt and I am very saticfied with the performance increase without a tune , the look ,It even sounds better then stock. I will be removing the venturi and going with the tune in the future, it is a great product I would recomend this kit .
ORIGINAL: Tigercat
an Airaid with no tune on V6
