Sponsored by:
Sponsored by:
stupid metal rattling noise at 3k rpm! EDIT: SOLUTION FOUND 9/7/07
Old 09-07-2007, 09:50 AM
  #21
hammeron
hammeron's Avatar
Default RE: stupid metal rattling noise at 3k rpm!
thanks for the follow up, this may help
a number of people down the road
hammeron is offline
Old 09-07-2007, 10:03 AM
  #22
CataclysmGT
CataclysmGT's Avatar
Why are you accelerating hard when the engine is cold?
At least they found the problem. Good to know there are some good techs out there.
CataclysmGT is offline
Old 09-07-2007, 10:05 AM
  #23
torch red
torch red's Avatar
Great job on finding out the issue...we will pass the word..
torch red is offline
Old 09-07-2007, 11:17 AM
  #24
imyy4u
imyy4u's Avatar
ORIGINAL: CataclysmGT
normally i don't, but one time i did and heard this noise...so i of course wanted to see if it was a one time thing or what. and it also happens on moderate acceleration too, or even light acceleration...just more noticeable with more gas.
imyy4u is offline
Old 09-07-2007, 11:51 AM
  #25
MTAS
MTAS's Avatar
Default RE: Solution found!!!!
ORIGINAL: imyy4u
So, I FINALLY got the problem fixed! My normal Ford dealership was closed, so I had to take it to Woodfield Ford in Schaumburg, IL. Luckily, they had seen the problem before - and they're trying to get Ford to issue a TSB about this as it is common. So, here is the solution - and if anyone else has a problem, tell them to call Woodfield Ford in IL - 847 882 5031 - they've fixed the problem before, and did it again with me!
EDIT: the problem was the spacer plate between engine and transmission contacting the back of the engine - print the following out and give it to your dealer if need be!
[IMG]local://upfiles/44457/50CF3B92AD2F47B29EA2C9419A316316.jpg[/IMG]
Thanks for the tip! I'll be doing this first http://forums.bradbarnett.net/showpo...mp;postcount=7 , before dropping the transmission. My car is out of warranty so I'm on my own. Also, on the invoice you have, it says "remove plate and off metal section that was making contact". It looks like there might be some words missing - "remove plate and off metal"?
MTAS is offline
Old 09-07-2007, 12:44 PM
  #26
ollied
ollied's Avatar
had similar problems in the crown vic
ollied is offline
Old 09-07-2007, 01:58 PM
  #27
07AlloyGT
07AlloyGT's Avatar
THANK GOD other people had this. i thought i was pinging badly. i talked to brenspeed a lot about it and used 93 octane on a 87 tune and it still made the same exact noise.
now i know my engine isn't getting destroyed when i drive.
07AlloyGT is offline
Old 09-07-2007, 02:31 PM
  #28
imyy4u
imyy4u's Avatar
ORIGINAL: MTAS
i think they meant "remove plate and cut off metal section that was making contact"or "remove plate and saw off metal section that was making contact" i don't know, maybe they just tightened the plate more, or something...regardless, this is a design flaw, not a manufacturing flaw, and it is present in a lot of mustangs and has worried a LOT of us who thought it was pinging, or something equally as severe since it sounds like it is coming from the engine...
imyy4u is offline
Old 09-07-2007, 02:32 PM
  #29
imyy4u
imyy4u's Avatar
ORIGINAL: 07AlloyGT
well, the rubbing can't be good, that's for sure. i'd still fix it ASAP before it has a chance to cause damage. but yeah, you're right, it's not something that will kill your engine, etc.
imyy4u is offline
Old 09-07-2007, 02:43 PM
  #30
Dex
Dex's Avatar
damn, i thought i was pinging too and figured it must be something else. While i have everything off my car i could take a picture of where its at and removing it
Dex is offline
Quick Reply: stupid metal rattling noise at 3k rpm! EDIT: SOLUTION FOUND 9/7/07
