Last edit by: IB Advertising
Browse all: Ford Mustang Interior Guides
- Ford Mustang V6 2005-2014: Interior Modifications
Step by step instructions for do-it-yourself repairs.
DIY THROTTLE RESPONSE MOD (MUST SEE!)
#501
IT WORKS !
I just did this to a 2006 stock GT. Worked great!! I just barely moved my brushes and it improved considerably.....
Thanks Man for the good ole fashioned advice! What other tricks do you have up your sleeve? More answers to problems like this are PRICELESS
#502
I just did this to a 2006 GT.I just barely moved my brushes a little, went to drive the car worked great for about 1mi from the house.. must of move the brushed too much ,i also notice a lot of carbon build up so i went to buy another one at ford $130.00
#503
did it on my 05 V6, Moved the cover box towards the firewall direction.
don't feel any change. the throttle response is like before. I think my problem is not the dead zone, it is the lag that when I hit the throttle the engine will not rev up immediately. also I looked at my rev1 part, seems my brushes are already touching the carbon part.
Maybe a ECU tune is the only way to fix the lag for me.
#504
Just did mine like this without having to bend anything. Just "clocked" the top of the cover where the plug is forward(towards the firewall) and all is good. Instant response on the pedal now!!!
10 minutes max spent on doing this mod!!! WELL worth it!!
Thanks for this tip!!
#506
resurrection of old thread. Would start new but too much info here to refer to.
Have a 2010 GT Premium. My wires were bent at a right angle and the arms were pretty much straight so I was not going to mess with the wires. I loosened the side cover that contains the circuit board and it didn't seem to want to move. I took out all the screw except the one farthest from the electrical plug. Once I did this the cover would slide back and forth. I slide it fully forward, moving the board towards the wires (front of the car). Installed and started the car. Great pedal response except the car now idled at 1200 RPM. I left the pedal hanging in the car and removed all but the bottom screw and the one on the top left. I then used a screwdriver to slide the cover back to where it no longer affected the idle. With the car running I installed the other 3 screws. The idle again increased. So I removed the 3 screws again and this time I installed the screws one at a time until I discovered which screw was affecting the idle. I then installed and tightened all but the one affecting the idle. Now when I installed the 5th screw it did not affect the idle. The cover holes are slotted, you may need to open the slots up a bit to make this work. It's VERY sensitive. Be sure your car is warmed up BEFORE you attempt to do this and definitely don't install the pedal until you have tested it. My .02
#507
just discovered this thread and read the first 5 pages and last 2 pages but still confused. Does this work for the 13' GT? what is this rotating the cover? i would like to try that before bending any thing any advice or tip will be appreciated.
#508
Norm
#509
I tried the proceedure where you slowly depress the pedal to the floor with the key in the on position. Held it there for 5 seconds and then slowly released the pedal. In my case it made no difference. Is there a better way to do it?
