DIY THROTTLE RESPONSE MOD (MUST SEE!) - Page 52 - MustangForums.com
Sponsored by:
Sponsored by:
Old 10-22-2015, 07:09 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Interior Guides
Print Wikipost
Old 03-24-2014, 09:46 AM   #511
mtgldr
mtgldr's Avatar
Quote:
Originally Posted by Norm Peterson View Post
I read rather recently where it was suggested to go through the procedure two or three times. No idea if that would help, but it couldn't hurt to try.
Norm
Back to back or turn off key between proceedures?
mtgldr is offline   Reply With Quote
Old 03-24-2014, 12:02 PM   #512
Tracedaddy
Tracedaddy's Avatar
Nice!!!
Tracedaddy is offline   Reply With Quote
Old 03-24-2014, 12:16 PM   #513
Norm Peterson
Norm Peterson's Avatar
Quote:
Not sure. I should have copied and pasted it into a file, but I didn't. If I run across it again I'll post it up.
Norm
Norm Peterson is offline   Reply With Quote
Old 03-24-2014, 11:05 PM   #514
mtgldr
mtgldr's Avatar
Found these:
Reset:
With the vehicle at a complete stop, set the parking brake.
Put the gearshift in neutral, turn off all accessories.
Turn on car without starting the engine.
Wait till the dash lights stabilize (some of them will turn off)
Step on the gas pedal in one smooth and steady motion
Once gas pedal hits the bottom, let go.
Turn off car and wait 4-5 seconds.
Turn on the engine.
Recalibrating the gas pedal and throttle body:
1- Turn the ignition to ON without starting the engine(dashboard lights come on and chime sounds).
2- After the chime stops, smoothly depress the gas pedal to the floor while counting 1001-1002-1003.
3- Release the gas pedal using the same procedure in 2.
4- Wait 6 seconds, and turn the ignition to OFF.
5- Wait 6 sec., and repeat steps 1-4 two more times.
You can here ticking when you do it and then the engine light blinks when your done.
Oddly in both forums people reported a benefit.
Old 05-23-2016, 12:15 AM   #515
Keaboy
Default your a fckn genius!!
Quote:
Originally Posted by tube View Post
Anyone ever notice that really anoying 1/2" or so of dead space in the gas pedal before the engine actually begins to rev?
My last car was a Subaru WRX with a cable throttle, I LOVED it, so responsive, so crisp.
Then I get my Mustang. The gas pedal is unresponsive, has load of dead space, and is a drivers nightmare.
Everyone always claims a tune helps their throttle response, so I purchased a Brenspeed C&L intake + SCT flasher combo. Unfortunately, 9 days after ordering it, no tracking # or item...
So today I'm at work thinking how I can mechanically remove that "dead space" in the gas pedal.
In my head, I picture the gas pedal module as being a carbon potentiometer, with a brush that is connected to the gas pedal, and moves, changing the resistance of the potentiometer, and thusly telling the ECU to open the throttle body.
Thinking some more, I decide to get my hands dirty.
I go in my footwell and look at my gas pedal. Simple enough, a black box with a plastic pedal coming out of it, three 10mm nuts, and 5 TORX screws holding a cover on the side, with an electrical connector and harness plugged into it.
I remove the three 10mm nuts, unclip the harness, and remove the entire pedal assembly.
Holding it my hand, I look at the cover, and take my T15 TORX driver and remove the cover. I pop the cover off, and VOILA to my assumption, a small circuit board, with a wedge shaped carbon film set of tracks, I think there are 6 to be exact.
I look at the inside of the gas pedal, and I see 6 little metal tabs, with about ten very fine metal wires, spot welded to the metal tabs, and bent up in a _/ shape to make contact with the carbon film on the circuit board.
I can clearly see a shiny track in the carbon on the circuit board where the metal brushes were rubbing against.
To my amazement, the track was starting about 2mm before the brush actually even TOUCHED the sensitive carbon part!!!
I take a pair of fine jewlers pliers, and bend each metal brush and tab just a few millimeters so that they will make perfect contact right on the edge of the carbon film.
I screw the cover back on, screw the gas pedal back onto the firewall and plug in the harness.
Start the engine, wait for the idle to drop. Perfect, idling around 700. I tap the gas pedal (with the tip of my TOE!)
and......
OH MY GOSH THE THROTTLE IS SO RESPONSIVE.
THE DEADSPACE IS GONE! ITS PERFECT!
It's amazing how such a small modification makes a HUGE difference in driveability and response.
If anyone wants pictures on how to do this, let me know.
Please digg my story!
http://digg.com/motorsport/Improving...chanical_Means
Step 1:
Remove Three 10mm nuts holding gas pedal to firewall:
Step 2:
Slide back red lock tab on connector:
Step 3:
Use flat head screw driver to press tab down inside of connector, and pull connector away from gas pedal assembly:
Step 4:
Take pedal assembly over to your workbench. Remove five TORX T-15 screws on electrical cover.
Step 5:
Remove electronic cover: Notice how the circuit board says REV 1.0? That means they haven't revised this gas pedal assembly since they first used it back in 2005!!! (My car is a 2008!)
Notice the circuit board with the wedge shaped carbon tracks. Notice the shiny marks on the tracks. See how they start slightly before the end of the gold track? That is your deadspace! Any movement before the very edge of the gold track will not be registered by the ECU!!!
THE ONLY WAY to fix this is mechanical adjustment. NO amount of tuning can remove this deadspace, it's simply impossbile!
Step 6:
Look at the pedal assembly. Notice the metal tabs and fine wire brushes? These are what we want to modify.
Very carefully, bend the brushes up so that they don't have such a steep angular bend in their tips. I have already done this in these photos, so it's not apparent how sharp the bend in the wires were prior to me modifying them. They are like this _/ and you want them to be straighter so that they move closer to the edge of the brass/carbon track.
Using some fine pliers, carefully bend the tips of the wires. These are VERY fine wires, be very careful.
Now bend the entire metal tabs up very slightly to compensate for the change in angle at the tips of the wires.
More pictures of the wires:
Another shot of the circuit board:
Notice that by bending the wires, we are moving them closer to the edge of the carbon/gold seam. This removes the dead space.
Step 7:
Put the cover back onto the pedal assembly. NOTE: There is a rubber gasket that goes in the slot. MAKE SURE not to lose it, or crush it, this could cause your vehicle to accelerate uncontrolably! Screw the 5 TORX screws back in VERY CAREFULLY do not distort the cover, or you may bend the wires and cause bad ju ju.
Re-install the pedal, and enjoy your new dead space free throttle!
I am not responsible if you ruin your 50$ gas pedal assembly by breaking off the fine wires, or over bending them.
Thankyou so much for this! I been feeling that lateness when I press the gas. And I finally did exactly what u were saying and tested it out and it fckn made a huge difference!!! It feels so much better and runs alot better! As soon as I hit the pedal there's no delay!!! Once again thankyou sooooo much for this!!!
Keaboy is offline   Reply With Quote
Old 11-07-2016, 05:53 PM   #516
chvyeter
My 2014 GT doesn't have the screws that hold the cover in place. I was going to just slide the over a bit and see what happens. Guess I'd have to try and dissemble it and see if I can adjust the brushes.
chvyeter is offline   Reply With Quote
Old 11-08-2016, 06:09 AM   #517
SilverStallion05
SilverStallion05's Avatar
Quote:
A 2014 is a whole different animal...
SilverStallion05 is offline   Reply With Quote
Old 03-08-2017, 07:17 PM   #518
VitalStang
Quote:
Originally Posted by 157dB View Post
One more time.
Add a stop to the travel and dont bend the brushes.
A 4-40 bolt and nut. Easily adjustable once its
installed without removing the pedal or taking
the case apart. I have had mine stopped for
months now before I joined the forum and
didnt think anyone here cared about the dead
spot in the accelerator pedal or I would have
posted the stop bolt mod.
Stop bolt modkills the WOT problem whether
there is one or not with the bending method.
I just limit where the pedal is at rest.
Do you have any pictures or a step by step write-up? I'm interested in trying this as it addresses the problem without fiddling with the brushes. I can see myself breaking those off! Thanks.
VitalStang is offline   Reply With Quote
Chassis wiggle when off throttle? UrS4 S197 Handling Section 10 10-03-2015 06:23 AM
High Pitch Whine. Help? FivePointToTheOh 2005-2014 Mustangs 9 09-29-2015 12:53 PM
Time for a new clutch? MasterLanMan 4.6L (1996-2004 Modular) Mustang 6 09-13-2015 08:21 PM
No power from my 3.8 94stangnewbe V6 General Discussion 0 09-07-2015 07:39 PM
197forumcomforumshowpostphpp31315amppostcount36, 2010, 4r3z9f836bd, 9f836, diy, ford, httpwwws, mod, mods, must, mustang, number, part, potentiometer, response, see, thottle, throttle
