Mustangs & Snow
#21
RE: Mustangs & Snow
ORIGINAL: p51mstg
MN outlawed studs before I was learning to drive, but you're right - nobody had FWD, except for maybe Saab, and those were rare enough. Everybody got around just fine with RWD.
ORIGINAL: GidyupGo
That's right. We didn't know what FWD was till the late 70's. If you wanted to go somewhere and it was slick out, saddle up! There were times when I drove on the ice and had one side of my car on the unpaved shoulder to get traction, but that was ice. No help there except studs or chains.
ORIGINAL: ilmor
The youngsters nowadays are nervous, I think, because they've grown up w/ front and all-wheel drive....
I know some states put limits on when you can use studs, but out here, you can use them year round. I never used them at all when growing up in southern Missouri where we got frequent ice storms. Had my first set out here and wonder why it took me so long.
#22
RE: Mustangs & Snow
Drove mine in the snow all last winter on the stock tires. I will have to admit that snow tires would help a lot but as long as you use common sense you will be fine even with the stock tires. The traction control is a big help in the winter.
#23
RE: Mustangs & Snow
The differences in snow vs all season tires are the tread and compound. Obviously the tread is more aggresive on a snow tire, but the compound is different so that it stays flexible when temps dip below freezing. That allows the tire to grip the ice and snow instead of allowing the car to be a lead sled. TC is helpful too. Never had either back in the ancient times. Old hard bias-ply snow tires and seat of your pants. Improvements have come a long ways.
#24
RE: Mustangs & Snow
i drove with TCS off alot of the time in the winter. if i was on a hill and i tried to get going my tires would spin and i slide back down, go back up, slide back down, go back up, slide back down, so i just said *** it and turned it off and just let it slip until i got to the top of the hill. then i would put it back on when i got onto the street.
#25
RE: Mustangs & Snow
ORIGINAL: Dwisforme05
Going uphill and through snow drifts, momentum is your friend. I used to live half way up a steep hill. About 1/4 the way to my house, there was a dog leg turn in the street and I had to get a run at the hill, drift around the dog leg, get straighten back up to continue up to my house and just about the time I was spinning and couldn't go any farther, I was home and backed into my driveway. It didn't help that the kids polished that hill nightly with their sleds.
#27
RE: Mustangs & Snow
I bought a set (4) of 235/55R17 Pirelli Winter 210 Sottozeros last season, and mounted them on take-off Bullitts for my 4.0L/auto vert. Those tires (w/ TCS) worked great in the snow! They are great in the rain too, and aren't much noiser than the P-Zeros.
I highly recommend getting good WINTER tires for a DD in snow. All-season tires will not cut it, IMO.
#28
RE: Mustangs & Snow
The Mustang is fine in the snow, the problem is the salt that is often used on roads that causes havoc and nasty corrosion on everything. When I live in snow country I had an old beater snow car to use in the winter. Even when the snow melts the salt stays on the roads for a long time.
