Last edit by: IB Advertising
Browse all: Ford Mustang Lighting Guides
- Ford Mustang V6 and Mustang GT 2005-2014: How to Swap Out Map Lights for LEDs
Step by step instructions for do-it-yourself repairs.
LEDS CONNECTED TO MAP LIGHT FOR FOOTWELL
RE: LEDS CONNECTED TO MAP LIGHT FOR FOOTWELL
ORIGINAL: odiaz
I installed lights in my footwell area earlier this summer. It's fairly easy to do. If you want to use LEDs, the procedure is similar. The only thing you need to worry about with LEDs is the polarity. If you wire it up and it doesn't work, simply reverse the wires. Here is a set of instructions.
http://www.cherod.com/mustang/HowTo/footwellLights.htm
Other how to articles can be found at this link:
http://www.cherod.com/mustang/HowTos.htm
http://cgi.ebay.com/10-Inch-Blue-Neo...spagenameZWDVW
so i went with two of these....so im going to have to cut off the cigarette adapter right?
i did a how to on this, and connected it to the parking lamps or something along those lines, so that when ever the orange lights or head lights were on, they were on.. so if i unlocked the car, the neons would light up..
you can try to find it, i took pics, and showed what wire to tap and all that
I did LED replacements for my map light and added lights to the rear above the back seats. I also mounted some LED's under the dash as well. Email or PM me for some detailed instructions I wrote up if you want them. I have pictures and wire colors all detailed, it's a little big to put up on here.
The write up is on the last post of the 1st page of this thread.
andrew1969
16
01-08-2016 02:48 PM
trashxtrash
09-20-2015 10:49 PM
TfcCDR
09-14-2015 12:08 PM
