Sponsored by:
Sponsored by:
Old 10-23-2015, 12:15 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Lighting Guides
Print Wikipost
LEDS CONNECTED TO MAP LIGHT FOR FOOTWELL
Old 09-26-2007, 11:57 PM
PennState
PennState's Avatar
Default LEDS CONNECTED TO MAP LIGHT FOR FOOTWELL
Ok so the other day i was at the gas station and i saw a mustang gt with leds or neons in his footwell. They turned on when he unlocked the car, so im pretty sure their connected to his map lights. Now how can i connect leds to the map light so that when i unlock the car or turn the map light on the leds in the footwell will go off. Also what do i need to buy to do this. Any help would be apreciated..thanks
PennState is offline
Old 09-27-2007, 01:03 AM
D_Gusler
D_Gusler's Avatar
Default RE: LEDS CONNECTED TO MAP LIGHT FOR FOOTWELL
What you see is the ambient lighting option for 2008 models. It is easy to add leds to the footwells. Go buy led strips, tap into whatever color wire is for the interior lighting(no need for a relay, as leds don't require much power). Your pretty much done. I know this is easier said then done, but it is a simple project to add.
D_Gusler is offline
Old 09-27-2007, 06:09 AM
PennState
PennState's Avatar
is their any right up on it...i dont wanna mess anything up
Old 09-27-2007, 08:21 AM
banka87
banka87's Avatar
It shouldn't be difficult if you have ANY experiance in car wiring.
banka87 is offline
Old 09-27-2007, 08:29 AM
PennState
PennState's Avatar
i dont really have any experrience with it..just installing an amp..
Old 09-27-2007, 08:30 AM
PennState
PennState's Avatar
also what size would i need
would these be fine
http://cgi.ebay.com/ws/eBayISAPI.dll...:IT&ih=009
Old 09-27-2007, 03:36 PM
D_Gusler
D_Gusler's Avatar
I would look for something between 5-8" to go in the areas. Any 12v led strip will work.
D_Gusler is offline
Old 09-27-2007, 03:53 PM
PennState
PennState's Avatar
5-8"?? is that enough to light up the footwell?
Old 09-27-2007, 03:57 PM
oshkoshbajawsh
I ♥ Acer
oshkoshbajawsh's Avatar
yes 5-8' would be enough.. look around for posts that guy with the silver eleanor like stang did some crazy led light thing in his car with a write up
oshkoshbajawsh is offline
Old 09-27-2007, 04:04 PM
odiaz
odiaz's Avatar
I installed lights in my footwell area earlier this summer. It's fairly easy to do. If you want to use LEDs, the procedure is similar. The only thing you need to worry about with LEDs is the polarity. If you wire it up and it doesn't work, simply reverse the wires. Here is a set of instructions.
http://www.cherod.com/mustang/HowTo/footwellLights.htm
Other how to articles can be found at this link:
http://www.cherod.com/mustang/HowTos.htm
odiaz is offline
Quick Reply: LEDS CONNECTED TO MAP LIGHT FOR FOOTWELL
