Wow! What a difference ... (Sound Deadening)
#33
RE: Wow! What a difference ... (Sound Deadening)
ThaiCobra : I didn't notice any difference in speed or handling ...
1morepart: I just remembered my pics .. I'll post them here in the next day or two!
#34
thanks again for this guide. I think I am going to begin this next month.
So just to clarify, if you were to do this again, how would you change the parts list in the Original Post
Second Skin Audio's Damplifier 80 sq ft - $187.20 (30 lbs) - Used to add mass to metal, and absorbs unwanted vibrations; the foil layer reflects unwanted sound
OverKill 36 sq ft - $43.13 (.468 lbs) - This is used to scatter the remaining vibrations that manages to pass through the Damplifier layer
Luxury Liner 36 sq ft $99.98 (I used ~27 sq ft = 27 lbs) - Used to absorb the last remaining vibrations that pass through the OverKill layer
Spray Adhesive 2 cans $23.94 - Used to attach Overkill & Luxury Liner
Panel Popper - $9.34 - Used to pull out pin-type retainers and trim
Wooden Hand Roller - $8.97 - Used to flatten Damplifier (saves your hands from cuts!)
Rags & Denatured Alcoh. $2.00 - Used to clean metal
#35
ThaiCobra : If I had the chance to do it over again, I guess I would use more Damplifier and less OverKill & Luxury Liner ... other than that, I'm pretty happy with the results.
Let's see if I can post some pix now ...
#36
First three pix ...
[IMG]local://upfiles/53981/A1DD6010682C46CAADC20B556532C28C.jpg[/IMG]
[IMG]local://upfiles/53981/751837A81C434506A56C5CE55401FD24.jpg[/IMG]
[IMG]local://upfiles/53981/EB692F116AF3462C8B91EFE5097A90CA.jpg[/IMG]
#37
Second set of three ...
[IMG]local://upfiles/53981/833EBC384AFC496A81DE4C46BAB4970A.jpg[/IMG]
[IMG]local://upfiles/53981/FD62D79163874D80A3E42C451C047777.jpg[/IMG]
[IMG]local://upfiles/53981/58A3D9C394684A47A909DFFC221B3C22.jpg[/IMG]
#38
Third set ...
[IMG]local://upfiles/53981/9DC71699EAF744F39E423BC1FCE410F6.jpg[/IMG]
[IMG]local://upfiles/53981/B8AAABFD66DD464084980A3BFE09AF0C.jpg[/IMG]
[IMG]local://upfiles/53981/FD2694983C334AF28C0D33A498B03A6F.jpg[/IMG]
#39
Last set ...
[IMG]local://upfiles/53981/A6559EFE3D49465E800358495749BB58.jpg[/IMG]
[IMG]local://upfiles/53981/5D1FE4D6C9AE41FC9030D522D631D9E2.jpg[/IMG]
[IMG]local://upfiles/53981/03C28C3385824BEE81DBDCD5AEE9CD0E.jpg[/IMG]
