Sponsored by:
Sponsored by:
convertible TSB
Old 10-24-2007, 08:48 PM
jawzz1
jawzz1's Avatar
Default convertible TSB
Hey all,
I wanted to post this for everyone in case you haven't heard. It concerns Mustang convertibles built BEFORE 10/11/2006. There is a problem with the #1 and #4 bow wearing or pinching the top. This could result in a hole being rubbed into the top. If you have this problem, the top will have to be replaced, and instal a kit to correct the problem.Mine 07 had this problem when I picked it up. It was a small rub on the driver's side just above the rear window. The TSB number is TSB 07-19-1.
jawzz1 is offline
Old 10-24-2007, 09:03 PM
Stkjock
Retired Mod
Stkjock's Avatar
Default RE: convertible TSB
never noticed.... thanks
Stkjock is offline
Old 10-24-2007, 09:43 PM
Rupp
Rupp's Avatar
I'm going to wait until 2 years and 11 monthsbefore Itake mine in.. .
Rupp is offline
Old 10-24-2007, 10:46 PM
beaustang
beaustang's Avatar
Thanks, I'm going to see what a fabric top would cost to upgrade to.
beaustang is offline
doobs
doobs's Avatar
Just to clear things up. Is this where the rub through is?
[img=http://img508.imageshack.us/img508/9167/sdskr3.th.jpg]
doobs is offline
Old 10-24-2007, 10:47 PM
TPony
TPony's Avatar
Must have superseded...TSb 06-22-16 that dealt with the same issue...thanks for posting...
TPony is offline
Old 10-25-2007, 02:44 PM
jawzz1
jawzz1's Avatar
ORIGINAL: doobs
It could be rubbing in the front. The TSB isn't specific where it's at. Mine is in the back, just above the rear glass on the driver's side.
jawzz1 is offline
Old 10-25-2007, 02:46 PM
jawzz1
jawzz1's Avatar
ORIGINAL: TPony
This one does supercede the old one.
jawzz1 is offline
Old 10-27-2007, 06:03 PM
Tri C
Tri C's Avatar
How can one tell if there is a problem? Interior inspection? Exterior inspection? Just by comparing the driver side to the passenger side?
Tri C is offline
Old 10-28-2007, 07:48 PM
Supercruzin
Supercruzin's Avatar
Checked mine this eve. Looks OK for now.
Supercruzin is offline
Quick Reply: convertible TSB
