really looks great armour, i may
be sold on this lowering kit now.....
I couldn't piece this kit together for any cheaper, so I went ahead and got the kit. It comes with new strut caps, lca relocation brackets, adj. panhard bar, springs and all the hardware. Everything you need to do it right, for now anyways.
How's the ride?
What is your tire size?
Did you install yourself?
It is a little bit more firm than it was with the stock parts, but just barely. I've got construction going on near my house so I can judge the difference pretty easily.
I have 255/35ZR20 tires installed all the way around.
I did the install myself and it took appox. 3 1/2 hours to do it, that includes getting all of the tools out. It was a fairly easy install. A floor jack and jack stands and some spring compressors from Autozone. Had only one screw-up during the install. I tightened down the lca relocation brackets without the sleeve and it started to colapse the brackets, but caught it in time to correct it.
