87 vs 93 Octane performance
RE: 87 vs 93 Octane performance
To answer your ECU question yes. There are improved timming maps that can be used with higher octane fuels. Higher octane allows more aggressive ignition timing and allows more margin for a hot lean A/F mixture without detonation so you can gain more power. From what I've seen an '05 is good for about 260WHP or so and this is backed up with the typical corrected quarter times most magazines have reported.
I tried the high octane gas and didn't notice any difference though the car was still new then. With the price now on a gallon of gas I'm just thankful that I can run 87 octane.
Higher Octane just give a small performance, but nothing to beat anyone in a race. And they only way to get a couple of HP from higher octane is to change the computer chip. Right now most chips are like 82 84 and that is what is will accept, put put 94 and only a littler different perforance. Change the cip and you can up the performance.
ORIGINAL: Daniel60
jwog666
12-27-2021 08:09 PM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
mungodrums
Suspension
09-24-2015 10:12 PM
05, 2005, 87, 93, advantage, called, difference, gt, make, mustang, octane, performance, recommended, running, whats
