Sponsored by:
Sponsored by:
Steeda swaybar install
Old 12-25-2007, 10:48 AM
taz9124
taz9124's Avatar
Default Steeda swaybar install
Can anyone tell me if this looks right or not???
taz9124 is offline
Old 12-25-2007, 11:05 AM
whtcanbrwnd04u
whtcanbrwnd04u's Avatar
Default RE: Steeda swaybar install
Mine looks similiar
whtcanbrwnd04u is offline
Old 12-25-2007, 11:12 AM
taz9124
taz9124's Avatar
I just wasnt sure if it was suppose to go over or under the rear body supports
taz9124 is offline
Old 12-25-2007, 11:14 AM
drbobvs
drbobvs's Avatar
Ah, sorry, you're upside down there pal. You need to flip it over (when looking from the back of the car, rotate it 180 degrees).
The bar should be above you cross braces. You don't need to remove your cross braces which is more of a pain in the *** than it seems. Just take off one rear wheel and slide the bar in from the side. You'll need to finagle it a bit because of all the twists but you'll get it in there pretty easily. The switch shouldn't take you more than 30 minutes with air tools.
drbobvs is offline
Old 12-25-2007, 11:17 AM
taz9124
taz9124's Avatar
Well I guess I got my answer... thanks a lot for the info
taz9124 is offline
Old 12-25-2007, 11:21 AM
Stkjock
Retired Mod
Stkjock's Avatar
yeah... I was thinking the same... the orientation of mine was different then the pic.
those billet brackets are nice!
Stkjock is offline
Old 12-25-2007, 11:23 AM
drbobvs
drbobvs's Avatar
While you're at it, replace those LCA's!!!! .
drbobvs is offline
Old 12-25-2007, 11:29 AM
157dB
Cut & Paste Expert
157dB's Avatar
ORIGINAL: drbobvs
Turn her over.
Bump in the center down.
[IMG]local://upfiles/69445/3DB32A19C05B4575B44774607810AED7.jpg[/IMG]
[IMG]local://upfiles/69445/6010058E07C748BC94AA9FC9D833BCC9.jpg[/IMG]
157dB is offline
Old 12-25-2007, 12:54 PM
taz9124
taz9124's Avatar
Got it guys.... problem is already corrected and i'm working on the rest... thanks for the input
taz9124 is offline
Old 12-25-2007, 01:00 PM
taz9124
taz9124's Avatar
I tell you what... upside down or not... it made one hell of a difference in the way she handled... and the wheels helped that much more
taz9124 is offline
mtgldr
02-03-2024 09:00 PM
09-10-2015 08:39 PM
robjh22
Suspension
09-08-2015 12:47 PM
09-08-2015 11:50 AM
09-02-2015 08:40 PM
Quick Reply: Steeda swaybar install
