Instrument Cluster Upgrade?
RE: Instrument Cluster Upgrade?
ORIGINAL: Rallsolo
Would you happen to have a link to that discussion? I would really appreciate it, and I appreciate the heads up on the switch!
http://www.allfordmustangs.com/forum...rument+cluster
so Rallsolo, I just got of the phone with ED the parts manager at the link you posted. he needs to talk to you buy the way. (he needs your vin to fill the order) he is checking into som questions i had about sending units and such. he also is checking on the switch we will need. he is going to email me with the info and i will let you know. thanks for geting this started im myself am looking forward to upgrading the dash
Hi Tom, here is the info, according to our lead master tech, the process to do the swap would consist of flashing old cluster and pulling out it’s data and then flash new unit and installing that data, basically a data swap, this can be done with a NGS PLUS or WDS ONLY! AS FAR AS OIL SENDING UNIT IT IS THE SAME FOR THE 4.0L AS THE 4.6L. The gauge is fed from the PCM and the gauge is really a dummy gauge and not a true pressure gauge if there is pressure it reads ok, if pressure drops the gauge drops. It does not read actual pressure. He agrees to do the upgrade the only thing needed to do is the flashing of the clusters and then PCM. Add switch and it should work.
Ed
Ed
Got all my parts in and am having the dealer install it Monday. One gotcha is a 300 core charge on the cluster. My dealer got the instructions on the upgrade from Ford and says there should be no issues. I'll let you know how it goes.
I dont get it.. for the IUP when you buy the car its what 400-450 with message center.. but if you got your car without it so you CAN get your car on a timely bases you would think we would give free install or a major discount. I wanted the IUP.. but even the dealers and sales people said not to get it because it would put a delay in getting the cars!!.. So now If I want it I have to pay 800-1000 for it?? Whos a@@ do we chew out?
ORIGINAL: lostsoul
