Sponsored by:
Sponsored by:
Cheapest Deal on clear corners?
Old 01-16-2008, 09:22 PM
banka87
banka87's Avatar
Default Cheapest Deal on clear corners?
Anyone?
banka87 is offline
Old 01-16-2008, 09:23 PM
whtcanbrwnd04u
whtcanbrwnd04u's Avatar
Default RE: Cheapest Deal on clear corners?
bump
i want to know too :]
whtcanbrwnd04u is offline
Old 01-16-2008, 09:32 PM
banka87
banka87's Avatar
Also, if anyone would happen to have a cheap place for Zex kits, I would appreciate that also.
banka87 is offline
Old 01-16-2008, 09:36 PM
Aziraphale
Aziraphale's Avatar
Usually ebay for $50 or less but I've heard a number of poeple say they leak. Howarmat went through 2 ebay pairs before picking up stangmods.com ones and hasn't had a problem since.
I personally have the stangmods ones. Be careful of the ones from Jegs, etc as they have an amber insert.
Aziraphale is offline
Old 01-16-2008, 09:37 PM
howarmat
s197 Junkie
howarmat's Avatar
+1 above....tis the truth
howarmat is offline
Old 01-16-2008, 09:38 PM
Aziraphale
Aziraphale's Avatar
ORIGINAL: howarmat
You're the reason I have stangmods ones so I always reference it
Old 01-16-2008, 09:39 PM
noober
noober's Avatar
Well I'll see how my ebay ones work. I avoided the Jegs one because of that amber insert. I got some other company's for about $40 shipped.
noober is offline
Old 01-16-2008, 09:41 PM
Aziraphale
Aziraphale's Avatar
ORIGINAL: noober
Some poeple never have problems with the ebay ones ... I just didn't want to deal with it. I've heard if you take them apart and run a bead of silcone around it to seal it off that helps too.
Old 01-16-2008, 09:51 PM
Bluestar
Bluestar's Avatar
What's up Chris, I have the E-Bay $39.00 Clear Corners, no leaks, no fog, clear and bright for 2 years........BTW I stopped by the F.H. but you were out on a run.....I see you still had the Numbers from the Track on the Driver's window.
Bluestar is offline
Old 01-16-2008, 09:53 PM
howarmat
s197 Junkie
howarmat's Avatar
yes, as long as you put the seals in yourself it shouldnt leak....its easy to do yourself so it depends on if you want to go through the hassle
howarmat is offline
Quick Reply: Cheapest Deal on clear corners?
