Plugs keep fouling out. Think I found out the solution - MustangForums.com
Old 01-17-2008, 08:38 PM   #1
Dex
Dex's Avatar
Default Plugs keep fouling out. Think I found out the solution
I change my plugs and the car starts a few times but runs lean. I come back a few days later and now the car wont start again and the plugs look the same as the last ones. Im wondering if they can go bad that quickly from being too lean? This is the best picture I could get. It almost looks like oil on it too...but there are new pistons and rings so how could that happen?
[IMG]local://upfiles/64043/83F27A8A7288448790ED4EFA54B43580.jpg[/IMG]
Dex is offline   Reply With Quote
Old 01-17-2008, 08:56 PM   #2
hammeron
hammeron's Avatar
Default RE: Plugs keep fouling out. Need some help
dex, do you have a vacuum/boost gauge?
if so, are you seeing normal vacuum readings,
when idling
hammeron is offline   Reply With Quote
Old 01-17-2008, 09:40 PM   #3
marcuskeeler
marcuskeeler's Avatar
It's not uncommon for a new build motor to use oil until it's broken in.
That plug looks like it's been too hot. How does it run? Air leak ?
marcuskeeler is offline   Reply With Quote
Old 01-18-2008, 02:23 AM   #4
Dex
Dex's Avatar
It wont idle because the tune was too lean. It sat at 16 onthe AFR and when i reved it to keep the car alive it went down to 15's. I got a new base tune that would be fine now but now i have to get a new set of plugs. I hope that it was just too lean and hot and burned them up. Because if thats not the case then there is something else wrong in the electrical part of the car
Im going to load the tune and new plugs tomorrow. Im hoping that is all this problem was. It just seemed odd that it could foul these plugs up so quickly.
WHy are our plugs 10 bucks each! jebus
Old 01-18-2008, 02:47 AM   #5
Simon1
Please keep us posted with the solution.
I doubt you have an electrical issue as it sounds more like a tune issue.
Simon1 is offline   Reply With Quote
Old 01-18-2008, 06:23 AM   #6
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
Esp if you are running lean the tune needs adj.... J
mygt500 is offline   Reply With Quote
Old 01-18-2008, 08:10 AM   #7
redfireshaker06
Quote:
ORIGINAL: Dex
Your not running a emailcanned tune for a power adder are you?????
redfireshaker06 is offline   Reply With Quote
Old 01-18-2008, 09:58 AM   #8
MustangGT0405
MustangGT0405's Avatar
Not a very good pic for sure but it defineatley looks like it was real lean.
Also to me "fouled" plugs are when you get too much oil in them and they can no longer produce a spark. A fouled plug you can clean and then it will work again. Yours are toast.
I hope you get it figured out and it is nothing major.
MustangGT0405 is offline   Reply With Quote
Old 01-18-2008, 11:28 AM   #9
modaddict
modaddict's Avatar
Running lean is asbout as bad as you can do to ruin your motor. Especially with the 2 piece plugs these cars use. That thing gets too hot, breaks the tip off and a whole lot of ugly possibilities pop up. (tapping a piston for one)
If you don't get a new tune, changing plugs is going to be the least of your worries.
BTW: When one of these plugs is fouled, it's not okay to just 'clean them off' - when they are fouled - they need to be trashed.
Back to Dex - are you sure you have enough fuel and spark for your set-up and power level?
modaddict is offline   Reply With Quote
Old 01-18-2008, 11:32 AM   #10
157dB
Cut & Paste Expert
157dB's Avatar
Too lean.
You seem to need an A/F meter set-up.
157dB is offline   Reply With Quote
Labor Day Weekend Special Granatelli Sales GT S197 General Discussion 5 03-25-2016 09:01 PM
Spark Plug Change 2007StangV6 2005-2014 Mustangs 30 01-28-2016 07:09 PM
Labor Day Weekend Special Granatelli Sales The New S550 2015-2016 Mustang 5 12-27-2015 07:28 PM
03 V6 Mustang Ticking Noise Emblazoned General Tech 0 09-03-2015 11:45 PM
AM or Bama please comment whatsup62 5.0L GT S550 Tech 1 09-03-2015 02:38 PM
05, 2007, 50, 89, faueling, ford, fouling, fuel, gt, mustaing, mustang, plugs, roush, spark, sparks
