High flow cats Vs. Stock Cats
RE: High flow cats Vs. Stock Cats
ORIGINAL: ApexStang
You just go to a shop that does not perform the visual inspection due to not having a lift.hmmm....Jiffy Lube comes to mind......
What Jiffy Lube do you go to? Every one I have been to have a pitwith a guy down there who drainsthe oil and change the filter. The only thing the guy up top does is fill and check the fluids and add oil.
ORIGINAL: SonicBlue05GT
the good thing with the Bassani X-Pipe is that it comes with straight pipe or the cats. so it can be an off-road pipe if you want it to be.
Sort of. Bassani offers two different x-pipes. One with the highflow cats, which does come with optional straight pipes. And the other is simply the x-pipe, which retains the stock cats, and requires cutting. They also have both those in stainless or aluminized (BX-series)
EDIT:
BTW: I passed smog easily with the catted x-pipe, CAI, and tune. Visual inspection on the cats was done also.
Luke9222
10-22-2015 11:55 PM
