Sponsored by:
Sponsored by:
recomended oil and filter
Old 02-04-2008, 08:42 AM
  #21
2k05gt
2k05gt's Avatar
Default RE: recomended oil and filter
Being that Mobil1 isnot 100% Synthetic it will work perfect for our cars, Exxon/Mobil designed it to work with 90% of the cars on the road. Mobil1 is as high qaulity as you can get in motor oil, it'son the High end of thePAO Group III Base stock,Mobil1 about 85% synthetic this makes it very compatable.
Motorcraft 5w20 part synthetic is about the same as Mobil1 in quality. But what is most important is the filter,
you needto get a quality filter, I can not stress this enoughwithouta good filter you arerecycling contaminates back into your engine, Motorcraft, K&N, and Mobil1 Filters are the Best over the counter, If you can find a WIX Filter they are fantastic.
I personally use K&N Filters and Royal Purple since I am looking for 100% Synthetic Oil, Royal Purple is avalable at Advance Auto Parts, Pepboys, Walmart and online. The other 100% true Synthetic Oils are Redline, Amsoil andany Extended life oils.,
If it does not say 100% Synthetic, it's not. Synthetic oils are derived from either Group III mineral base oils (only in the USA - in the European Union, Group III can NOT be classed as synthetic), Group IV, or Group V non-mineral bases. True synthetics include classes of lubricants like synthetic esters (Group V) and polyalpha-olefins (Group IV).
I say Mobil1 is top knotch and Walmart has the Best Price on Mobil1 oil, 21.00 for 5.5gt jug and Mobil1 filter for 4.50.
2k05gt is offline
Old 02-04-2008, 10:10 AM
  #22
ruger3.5
ruger3.5's Avatar
When would you want to use 100% synthetic, is it more of a performance preference?
ruger3.5 is offline
Old 02-04-2008, 11:15 AM
  #23
Rubrignitz
Rubrignitz's Avatar
Yes, synthetic media can filter down to5 micron and because of it's efficiency can hold more particles. I used to use Mobil1/K&N filters (still very good filters) until I researched the new Amsoil full synthetic media filters. It changed my mind.
http://www.bobistheoilguy.com/forums...34&fpart=1
Rubrignitz is offline
Old 02-04-2008, 11:34 AM
  #24
gatkins94
gatkins94's Avatar
ORIGINAL: ZZLEGEND
factory motorcraft 5-20 synthetic blend here..and a motorcraft oil filter..wal-mart sells the motorcraft oil filters at half the price of the dealers, and i think they carry the same oil now to..
I agree totally with this poster!
gatkins94 is offline
  #25
Leoleo
Leoleo's Avatar
ORIGINAL: 2k05gt
I was at two different Walmarts this weekend. Both had Mobil 1 oil, but niether had the filters.
Leoleo is offline
Old 02-04-2008, 11:52 AM
  #26
Grabber
Grabber's Avatar
I use 5W-30 Royal Purple, and a K&N Filter. My engine feels so much smoother. Not to mention with Royal purple...If you put 5 qts in. you get 5 back....It is also geared toward the performance vehicle, which is why I use it.
Grabber is offline
Old 02-04-2008, 12:32 PM
  #27
ruger3.5
ruger3.5's Avatar
Are the K&N oil filters at places like Auto Zone. Ive seen the Bosch, dont recall seeing a K&N though.
ruger3.5 is offline
Old 02-04-2008, 01:48 PM
  #28
Grabber
Grabber's Avatar
I purchased my filter from Murray's. I believe that Advance Auto parts has them as well....
Grabber is offline
Old 02-04-2008, 08:34 PM
  #29
2k05gt
2k05gt's Avatar
ORIGINAL: Leoleo
ORIGINAL: 2k05gt
I noticed that some don't carry the Modil1 filters, hmmgo to Autozone or Advanced auto and pickup a couple and youwill always have one avalable.
To answer ananother post, Yes, 100% Syntheticforthe added protection forRacing,I dabble inRally and Drag Racing.
HERE ARE SOME PART NUMBERS JUST INCASE YOU NEED TO SEARCH THE NET FOR SOMETHING
2005-2008 FORD MUSTANG 4.6L 8-cyl Engine Code H
FILTERS
Oil Filter: EAO11 Absolute Efficiency Oil Filter
Oil Filter: 51372 WIX 51372 Oil Filter (O)
Oil Vapor Filter: N/R
Air Filter: 46975 WIX 46975 Air Filter (O)
Fuel Filter:33243 WIX 33243 Fuel Filter
Trans Filter:58844 WIX 58844 Auto Tran Filter
Cabin Filter: 24687 WIX 24687 Cabin Air Filter (0)
NGK PLUGS & WIRE SETS
NGK Plugs CPB-FD001 NGK58901 [1]
1.SOHC (8 CPBs Req'd)
2.SOHC (No Wires Req'd)
TRICO WIPER BLADES
Blade Class NEOFORM
Driver T16220
Passenger T16200
Blade Class EXACTFIT
Driver T221
Passenger T201
Blade ClassWINTER
Driver T37225
Passenger T37205
Blade Class OKTANE
Driver 22 inch
Passenger 20 inch
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......API*
100% Synthetic 0W-20 Motor Oil
SAE 5W-20 XL Synthetic Motor Oil
SAE 0W-30 Synthetic Signature Series Oil
All Temps......5W-20[1]
Manual Transmission,.....MA5
Synthetic Automatic Transmission Fluid
Automatic Transmission.....MA5
Standard Differential, Rear W/ 7.5 ring gear.....GL-5[2]
All Temps......75W-140
Severe Gear 75W-140
SAE 80W-140 Synthetic Gear Lube
Controlled Slip Differential, Rear W/ 8.8 ring gear.....GL-5*[2][3]
Severe Gear 75W-140
Fluids
Power Steering Fluid.....MA5
Brake Fluid.....HBH
Series 600 DOT 4 Racing Brake Fluid
Clutch Fluid.....HBH
1. Use Ford part no. XO-5W20-QSP or equivalent
motor oil meeting Ford specification WSS-M2C153-H.
2. Synthetic oil is required.
3. Traction-Lok axles add 4oz of friction modifier Ford part No
XL-3 or equivalent meeting Ford spec EST-M2C118-A
CAPACITIES
Engine, with filter..........6.0 quarts[1]
Cooling System, Initial Fill..........16.0 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, Total Fill
5R55S..........12.0 quarts
Manual Transmission, ..........6.3 pints
Differential, with 7.5 ring gear Rear..........3.2 pints[2]
Differential, with 8.8 ring gear Rear..........4.2 pints[2]
1. After refill check oil level.
2. Fill to no more than 1/4 to 9/16" below fill plug hole.
TORQUES
Oil Drain Plug.....18 ft-lbs
Manual Transmission T50D
Fill Plug.....13 ft-lbs
Drain Plug.....17 ft-lbs
Manual Transmission TR3650 5-SPD
Fill Plug.....18 ft-lbs
Drain Plug.....20 ft-lbs
SERVICE INTERVAL
AMSOIL Product Recommendation and Drain Interval Guide (g1490)
AMSOIL is a Sponsor here give them a try you might like it
2k05gt is offline
Old 02-04-2008, 08:37 PM
  #30
Burnsy
Burnsy's Avatar
ok this thread is now worthless
Burnsy is offline
Quick Reply: recomended oil and filter
