Steeda Carbon Fiber inlet tube. WOW!
All I can say is WOW. I have been using the Saleen inlet tube and getting around 8-9 psi of boost and around 10 at redline. Just installed the Steeda Carbon fiber inlet tube went out driving and hit 12 pounds BEFORE REDLINE!!! I kept playing around and my boost is in fact all here. I could not believe how bad the Saleen inlet tube really is. From my experience I would not recommend The Saleen inlet tube to anyone
RE: Steeda Carbon Fiber inlet tube. WOW!
Was the original intake tube flexible? It looks like the stock Mustang one, which, under heavy throttle will partially collapse, causing less airflow.
A solid tube is the way to go!
Amazing!
I have just a regular Steeda CAI w/elbow. How did you get it to fit the Saleen? Did you buy motor mounts?
Also, isn't reaching 12 psi kind of a bad thing [&:]
P.S. That engine bay looks amazing.
ORIGINAL: Pwny
Amazing!
Amazing!
I did install lowering mounts a few months back. I've watched the inlet tube on the dyno and it never moved so I was pretty sure it never collapsed. It was still a huge pain to get it to line up correctly it wasn't a simple install. I've always used the saleen inlet tube and never had full boost so I kept throwing pulleys at it to get some more.
I would also like to add I normally see IAT's of 107 - 111 driving. Today is was going between 87 and 88!. I never had these good of numbers evenwhen itwasREALLY cold out.
ORIGINAL: Pwny
How hard was it to install motor mounts?
ORIGINAL: sevenleaf
We did the motor mounts the same time we did the exhaust so they were fairly easy. We also used a lift so I know that helped. Headers, OR xpipe, motor mounts and A-ARM bar took less then 4 hours.
ORIGINAL: Pwny
