Sponsored by:
Sponsored by:
check engine light
Old 04-06-2005, 02:58 PM
bigredgt
bigredgt's Avatar
Default check engine light
anybody had the problem with check engine light coming on and off somtimes if so is there a trick to fix it so i dont have to go to the dealer
bigredgt is offline
Old 04-06-2005, 04:42 PM
Red69Sportsroof
Red69Sportsroof's Avatar
Default RE: check engine light
ORIGINAL: bigredgt
Disconnect your battery cable for a few minutes - reconnect and the check engine light should be off. But, if it continues to come back on - get it checked out. I think Auto Zone will check it for free (if you have one in your area).
Red69Sportsroof is offline
Old 04-06-2005, 05:06 PM
bigredgt
bigredgt's Avatar
i tried that and still comes on and im stationed in germany and the ford dealer cant service my mustang yet
bigredgt is offline
Old 04-06-2005, 06:02 PM
td1320
td1320's Avatar
ORIGINAL: bigredgt
Any run problems? Mine is bogging bad and the dealer here in virginia has no clue. The check engine light will not go out and it went into Fail Safe mode twice. The Detroit tech rep is flying in to figure it out.
td1320 is offline
Old 04-06-2005, 09:43 PM
Earl
Earl's Avatar
A friend at work also has a GT. His has come on and gone into failsafe mode....the dealership has had the thing for 2 weeks now. Whatever part they need for it is on national backorder - seems kinda like a common term with our cars huh?
At least my national backorder part was simply a bolt and I kept the car till it came in.
His car has now been at the dealership longer than he has had it.
Earl
Earl is offline
Old 04-06-2005, 09:48 PM
cheysdaddy
cheysdaddy's Avatar
I've been told that the bogging down thing is due to something Ford put in the fly by wire throttle control to protect the transmission and rear end. You supposedly can take it out by doing a reflash with like a Xcalibrator or Predator
cheysdaddy is offline
Old 04-06-2005, 11:58 PM
dukenitro
dukenitro's Avatar
are you using 87 octane. DO NOT USE PREMIUM FUEL until you reflash computer.
dukenitro is offline
djbigskrilla
09-20-2022 01:04 AM
labudski
08-24-2015 07:23 AM
microgt
08-20-2015 07:12 AM
mweiland
08-13-2015 05:11 PM
drumhedd2005
08-13-2015 09:59 AM
Quick Reply: check engine light
