Remote Starter Help
what does it mean by starter side and key side with the Violet and Green wires from the viper system? I'm assuming that after cutting the green wire, the Green wire from the viper should go to the connector that connects to the ignition and the Violet wire should go to the cut green wire that runs to the harness (rest of car) . But in the Viper 5900 install video by Motorz, they wired the Violet wire (+starter output; starter side) to the cut green wire of the connector, and the Green wire (+ starter input ; key side) to the cut green wire that runs to the rest of the car (opposte) doesnt sound logical. Which is the right connection?
Also, do both door trigger inputs used? The H2/6 Green Door Trigger Input (-) and the H2/12 Violet (+) Door Trigger Input? thanks in advance
logan409
09-26-2015 07:43 PM
jaiidutch
09-14-2015 10:29 AM
